Question about WYSE C90LEW 2GB2FL DVI IW US Video Card
How to make the screen rotate 90 degrees - WYSE C90LEW 2GB2FL DVI IW US Video Card
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Jan 21, 2013 | Intel S6240 Notebook
Acer tablet troubleshooting
b>
Jan 14, 2013 | Computers & Internet
Change screen orientation
b>
Dec 14, 2012 | Dell Computers & Internet
P c screen upsidedown
Hope this helps
Oct 20, 2012 | Fujitsu Siemens ESPRIMO MOBILE V5535...
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
Nov 16, 2009 | Samsung NC10-14GW Notebook
My monitor display has rotated itself 90 degrees counterclockwise and I do not know how to return it to it's normal position. What do I do to return it to it's normal "Landscape" position?? I have a...
on the front of the toughbook there are 4 small buttons, the 3rd from the left which has a right angle symbol with a double headed arrow in it rotates the screen 90 degrees each time you press it. this is probably how you got it like that in the first place.
Aug 05, 2009 | Panasonic Toughbook-19 Tablet PC
WYSE C90LEW 2GB2FL DVI IW US Video Card Logo
Top WYSE Computers & Internet Experts
Rick Johnson
Rick Johnson
Nicholas Bannister
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
