Question about Ganz Home Security
Dvr no hdd found - Ganz Home Security
I have a 4 channel Sunluxy H.264 Network DVR, I have fitted a 300gb HDD but although the system is working and I get the 4 cameras on screen the message I keep getting on boot up is HDD not found
Guys this one stumped me for some time, here is my solution that worked like a dream
1. plug the hard drive you are using into a pc and check the hard drive is recognise and works.
2. Delete all partitions
3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
MANUFACTURER MODEL CAPACITY ROTATION
ST3320613AS 320GB 7200 rpm
ST33500320AS 500GB 7200 rpm
ST3750330AS 750GB 7200 rpm
Seagate
ST31000340AS 1000GB 7200 rpm
WD3200AAKS 320GB 7200 rpm
WD5000AACS 500GB 7200 rpm
WD6400AAKS 640GB 7200 rpm
WD7500AAKS 750GB 7200 rpm
WD10EADS 1TB 7200 rpm
WD15EADS 1.5TB 7200 rpm
WD
WD20EADS 2TB 7200 rpm
Maxtor STM3500320AS 500GB 7200 rpm
STM3750330AS 750GB 7200 rpm
HITACHI HDT725032VLA360 320GB 7200 rpm
HDS721010KLA330 1000GB 7200 rpm
FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
Cheers.
Jan 11, 2013 | Home Security
I have a Lorex edge LH314 320GB, DVR beeps and displays HDD is not formated.
You need to format the hard drive using the built in formatting utlity. Did you replace the hard drive in the DVR maybe?
Nov 15, 2012 | Lorex EDGE L314501C4 4-Channel Network...
When i reboot my Zmodo dvr I Can't get menu to come up or mouse to work HDD light keeps flashing,blinking hdd light,HDD indicator light
I had the same problem. Did their online tech support and Patty told me to hold down the "rewind" button on the DVR for 20 secs. You should now be able to right click your mouse to access the on screen menu. You will now want to go under system, and a/v setup and change the device to VGA instead of Vout. Now you can reboot and not have to go thru holding down the buttons anymore. Worked for me.
Oct 02, 2012 | ECHO1USA Zmodo 4 Ch Complete Dvr Kit -...
Does not record programes
Most likly there is a problem with the HDD on the DVR if that is what you have DCT look like DVR's but do not have a HDD; If this is a DVR you will need to call you're provider or the manufacture of the DVR and have them Trade out the DVR; Never open the DVR and try to replace the HDD you're self you will damnage the box byond repare;
Aug 27, 2011 | Televison & Video
Copying CCTV DVR data to external HDD for storing data
use the software that comes with ur dvr. connect to it via lan.. and save the infor in to ur computer
May 15, 2010 | Western Digital Passport WDXML800UE...
How to upgrade hdd for Samsung DVR HR737
If you want to play your videos from your computer to your dvd the best way i have found is download realplayer when its downloaded and your ready to go. Go to burn and transfer cd in the options on the burn page at top it lets you change formats.The format you need to use to go from computer to DVD player is vcd it has a DVD format but i don't have a DVD burner so i haven't tried that format yet.Hope this might help.
God Bless Greg
Here is address: http://www.real.com/ i use the free and it works great
Nov 11, 2008 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Set HDD to master
The internal power supply to the HDD is often suspect in these units. Check you have power on the internal plug to the HDD from the circuit board. if you do not Try fitting an external HDD power supply (£15) this cured my unit which had a similar fault.
Hope this helps - good luck.
Jul 23, 2008 | Swann Communications DVR4-Alert Video...
HDD Error
Since my last post, I have rectified the problem.....
1) I opened the unit to find a seagate HDD
2) I downloaded the Seatools in dos format and burned the image on to a cd rom
3)Taking out the HDD from my recorder,I hooked it up to another pc and ran the seatools disk @ bootup.
I tried for 2 hrs to repair the bloody thing ( 160 gb!) so i gave up and tried to erase the full HDD...which worked.
4) on my laptop i navigated to Pioneers site and found my recorder along with instructions and a zip file that contained 2 files.
5)After reading the destructions erm i mean instructions ;) I put the HDD back into the recorder and followed the instructions again..
Crossing my fingers i turned the recorder back on and to my amazement i was able to have more functionality..BUT... it says my HDD name error so I ran the disk again and wallah! all worked XDDDD
Here are the links
http://www.pioneer.co.uk/uk/content/support/support/update/DVR.html check if your model is there.
http://download.seagate.com/seatools/registration.nsf/desktop?openform Just add your email too download.
I hope you fix yours XD
May 05, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Home Security Logo
Top Ganz Home Security Experts
David Payne
David Payne
Lawrence Oravetz
Are you a Ganz Home Security Expert? Answer questions, earn points and help others
