Question about Exercise & Fitness
Gymtrim exercise manual - Exercise & Fitness
How can I reset the "programmed exercise mode" on my Kohler 12 RES generator
You will likely need to reference your instruction manual for that specific control panel.
Aug 07, 2016 | Kohler 12 kW Emergency Power System -...
Parabody 350 home gym manual
This program http://workoutguru.us/ contains every possible exercise, and muscle building tips (including exercises with your parabody 350). Just follow it, and be persistent. Do not forget to take before/after photo's :). best of luck
Mar 02, 2013 | Exercise & Fitness
Bodyfit exercise bike by Sports Authority manual. Where do I find the manual?
This program http://workoutguru.us/ contains every possible exercise, and muscle building tips (including exercises with your bike). Just follow it, and be persistent. Do not forget to take before/after photo's :). best of luck
Oct 20, 2011 | Fitness Quest Edge 482U Upright Exercise...
The bike goes to Pause mode frequently throughout the workout. I have tested all the exercise modes and made sure my RPMs stay the same but it just flips to pause and then starts working again...
Star Trac Pro Upright Bike Owner's Manual - ManualsLib
www.manualslib.com > ... > Exercise Bike > Pro Upright Bike
Exercise Bike Star Trac Upright Sport Bike Owner's Manual. Stationary sport bike (28 pages) ... Pro Upright Bike Pro Recumbent Bike ' W N E R A N U A L..
Jan 20, 2011 | Star Trac Sport Recumbent Exercise Bike
What is the proper proceidure to set exercise timer on a briggs generator model # 01938 and what year was this model manufactured? thank you
http://www.homegeneratorsystems.com/service_support/manuals/index.cfm?rd=1
This link will take you to their site where you can download their manual.
Setting Exercise Timer
The Home Standby Generator is equipped with an exercise
timer that will start and exercise the system once every
seven days. During this exercise period, the unit runs for
approximately 20 minutes and then shuts down. Electrical
load transfer DOES NOT occur during the exercise cycle
(unless an utility power outage occurs).
A switch on the control panel is labeled “Set Exercise”
(depicted on page 10).The specific day and the specific time
of day this switch is pressed is programmed into the
control board memory.This date and time is then used to
automatically initiate the system exercise cycle.
To perform the Set Exercise procedure:
1. Choose the day and time you want your Home
Standby Generator to exercise.
2. On that day and time, set the AUTO/OFF/MANUAL
switch to OFF.
3. Press and hold down the “Set Exercise” switch for two
seconds.
4. Set the AUTO/OFF/MANUAL switch to AUTO.“Set
Exercise” is complete.
For example, if you press the “Set Exercise” switch on
Sunday morning at 10:00 AM, the unit will run an exercise
cycle the following Sunday at 10:00 AM (+/- 1/2 hour).
NOTE: “Set Exercise” will only work if the unit is in the
Automatic mode and this exact procedure is followed.The
exerciser does not need to be re-set if the 15 Amp fuse is
removed or changed.The exerciser will need to be re-set if
the 12 Volt DC battery is disconnected.
If you want to change the day and time the unit exercises,
simply perform the “Set Exercise” procedure at the exact
weekday and time you want it to take place.
• To prevent possible injury that might be caused by such sudden
starts, always set the AUTO/OFF/MANUAL switch to OFF.
• Remove the 15 Amp fuse before working on or around the
generator or transfer switch.
Nov 12, 2009 | Briggs & Stratton 12,000 Watt Bi Fuel...
Exercise & Fitness Logo
723 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
