How to install ftp send for canon ir 3035 - Office Equipment & Supplies
Cogz
  • 1326 Answers
SOURCE: the 20 GB hardisk drive of my ir canon 3035 copier is damaged how
how do you know the hard drive is bad? Do you get a error code E601-001 ? You can just buy a 20G HD, but you are going to have to get Flashed or programed with the running system.... Did you look on line?
Posted on May 15, 2009
SOURCE: I have a canon copier
this error is power related. reset the fixing error by pressing * 2 & 8 then * Go to function, clear, error switch off the machine then switch on
Posted on Sep 03, 2010
edy_bubat
  • 306 Answers
SOURCE: canon ir 3035 xerox machine
that is about toner,
- may be toner was empty (the first you must try) after you fill the toner, you must turn off and on again.
- toner sensor was loose or broken (second trial )
- toner motor was not work.(the last)
good luck
Posted on May 17, 2011
canontech
  • 1219 Answers
SOURCE: My canon machine is IR 3035 and having a error
this is error code for abnormal temperature rise in fixing section.
You can try to reset error in service mode, but if the problem persist you need to change the fixing film unit.
To reset the error:
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel.
Choose: COPIER>FUNCTION>CLEAR>ERR.
Turn off and back on.
Hope that helps!
Posted on Aug 22, 2011
MNfisherman
  • 11896 Answers
SOURCE: canon copier IR 3035 printer port not recon zing in computer
You may need to download or update the drivers.
Drivers are what synchronizes the computer to the printer.
You can download them free from the printer's manufacture's website
Posted on Jun 10, 2012
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
How do i fix power on paper jam on canon ir 3035 copier?
Probably one of the sensors on the papers way through the machine is out of position,or not working
Mar 05, 2015 | Canon Office Equipment & Supplies
MY CANON IR 3035 START UP PROBLEMS
you are not very clear in you problem but i think that maybe you have to make the firmware first of the copier and than if does not work change the hdd and again firmware.
Oct 31, 2014 | Canon iR3035 Copier
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Canon copier IR 3035 printer port not recon zing in computer
Jun 09, 2012 | Office Equipment & Supplies
My canon machine is IR 3035 and having a error code E000001-002 How can I fix this.
To reset the error:
Hope that helps!
Aug 22, 2011 | Canon imageRUNNER 3035 Black and White...
I have a canon copier ir 3035, its giving error code E000002-0000, whars the problem?
Aug 21, 2010 | Office Equipment & Supplies
Canon 3035 missing drawer options
On your computer go to the start menu,select control panel,printers and faxes,right click on the ir 3035 driver,select properties from there go to device settings.In the paper source options inable the casette unit.
Then you will be able to print from the extra cassette unit.
Mar 13, 2009 | Canon imageRUNNER 3035 Black and White...
k24674
jasbo
jasbo
