Question about Brother Office Equipment & Supplies
Refill brother LC40BK ink cartridge - Brother Office Equipment & Supplies
SOURCE: HP PSC 2355 Won't accept refilled ink cartridges
If problem is what I think it is (that is if you cleaned whole thing and it is connected proprely), you have only one option. To buy at least three cartridges...problem is due a small trick made by HP. Printer remembers at least two cartridge serial numbers, and then wont accept refilled ones. But if you first stick one, then the other, and on the end the third one(only this one should be really full) it should reset printer and it should foul it to accept it. But on some printers it needs up to five cartridges! What a waste of money :( Anyway, hope this helps...
Posted on Sep 28, 2007
SOURCE: Brother laser cartridge refills
OK.. I agree that your problem is with the flag gear. However, there is a specific location in which it needs to be situated. The purpose of the flag gear is to trip a reset actuator on the left side of the printer. The correct position of the flag gear needs to be set so the reset actuator is depressed 3/4 of the way AND where the flag gear moves out of the way once this is done. If the flag gear is moved all the way forward, you run a risk of the gear mechanism inside not rotating it out of the way...which could leave you with a 'no cartridge installed' message. When the manufacturer of the toner cartridge made this unit, they decided to put a mark on the side to, evidently, let the assembly team know where to set the flag gear. Great for us :) On the outside plastic piece that you have to remove to get to the flag gear, you will see a diagonal line and a view window. When you rotate the flag gear, you will eventually see a portion of the white gear in that view window. Line up the white gear portion with the bottom of the diagonal line (typically two gear teeth), and you're done. Assemble and run!
Posted on Aug 01, 2008
sebpan
  • 7 Answers
SOURCE: how to refill brother lc61 ink cartridge
Trust me, this is the BEST way and the EASIEST way to refill black and color LC61 or LC65 inkjet cartridge from Brother. See the pictures
1. cut the plastic part (see picture). You can use a utility knife or a steak knife (very easy to do)
2. make a hole on the left or right side (NOT in the midle) and do it straight and don't go deep (see picture)
3. poor the ink with your refill kit and do it straight and don't go deep because the inner side of the cartrigde is made of cheap plastic (like a plastic bag) and you don't want to perforate it
4. put your plug, tape, hot glue or what ever you have to seal the hole.
5. put the cartrigde back in your printer, do a print test and that's9d5859a.jpg8c316c6.jpg it !!!
Posted on Feb 01, 2010
pineworks
  • 4041 Answers
SOURCE: Just replaced ink cartridges on my Brother MFC
Hi there you can refill Brother cartidges, like other printers it will not have it sorry.
This is the only way you can trick it.
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 04, 2010
  • 7 Answers
SOURCE: How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Posted on Jun 01, 2010
How to refill Brother LC101 ink cartridges
many manufacturer's have made the cartridges so they can not be refilled , but only replaced with OEM cartridges . they chipped them .
Apr 14, 2016 | Brother LC101BK Ink Cartridge
It tells me the cartridges are empty, then when i open the lid it says no cartridge! its not been used for a few months, and i refill them with generic refills...any thoughts? tried the switch off and on -...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Make sure that your ink cartridges are full and that they are genuine brother inks; refills or generic ink cartridges are not guaranteed to work properly.
Thanks,
Pat
Mar 29, 2010 | Brother MFC-620CN All-In-One InkJet...
How to refill Brother LC51M ink cartridges?
how do i refill brother innobella ink cartridge
Dec 12, 2009 | Brother Office Equipment & Supplies
How to refill brother LC38 cartridge
The cartridge is requires to be refilled immediately when it runs out of ink otherwise the print head gets dried up and becomes unusable.
Remove the ink cartridge; in the front side you'll see a small lever moving in side the transparent cartridge above the ink supply nozel. This is the sensor and tells about the ink quantity in the cartridge.
very carefully make a pin hole in it and use a 5ml syringe filled with "CISS ink" and not ordinary ink. CISS Ink is specially meant for continuous ink supply system and easily available for little higher price than normal ink.
Remember that the side walls of your Brother ink cartridges are made of transparent polythene and hence when injecting the needle of the syringe be careful that it does not go puncture the side walls and goes straight vertically. Injet the ink. Seal the pin hole with wax. You can use burning candle to drop little melted wax over the hole.
The better idea would be to break open a cartridge and see for yourself so that you dont damage the side walls accidentally.
The refillable ink cartridge set is available just for US $ 9.30 shipping paid from eBay.com I am using that set. Be careful Brother would void your warranty if it finds out that you are using refillables.
_Sqn. Ldr. Raman K Jhanjee (Retd)
Dec 09, 2009 | Brother DCP 165C Compact Color Inkjet...
Unable o clean
HTML clipboardHi If your brother printer has been left unused for some time it is probably clogged? And the inbuilt cleaning facility does not help then you will probably need to buy a Magic Inkjet Flush Print Head Cleaning Kit.
Which you can find on Ebay.
http://tinyurl.com/yfx2y5k
Although it is possible to take the Brother printers apart, it is too difficult for most people.
To view what´s inside a Brother Printer click on next line...
Click again to enlarge photo.
http://magicinkjetflush.com/images/Unclog_Refill_Brother_Printers.jpg
Therefore, what we suggest is to make cleaning cartridges using the Dr.EpSUN Refill Tool...
Then use them to flush the print head (usually at the end of long tubes near to the back of the Brother printer)
*NEVER TOUCH THE WHITE star shaped PIN... under ink cartridges... because once pessed in... it cannot be used !
Also in most cases a single cleaning cartridge for black and 1 for colour is all you will need.
If you only have FULL INKS and need to make a cleaning cartridge use Dr.EpSUN Refill Tool to empty ink cart...
Save the ink in a clean glass jar or similar make cleaning cartridge then once unclogged simply use Dr.EpSUN Refill Tool
to refill with your saved ink.
How to make Brother Cleaning Cartridges
If you wish to see photos? You can also follow the procedure for Epson C80 in the Magic Inkjet Flush Manual.
Using FREE Dr.EpSUN Refill Tool.
To refill Brother inks... or if printer has been left unused and you need to unclog print head? (To make a cleaning cartridges *Fill empties with Magic Inkjet Flush instead of Ink / Then print rectangles using Magic Inkjet to FLUSH print heads once prints appear without white lines simply replace with inks and continue printing rectangles untill all Magic has been flushed out of print head.)
How to refill Empties...
1. Secure empty Brother ink cartridge UPSIDE DOWN in a vice or similar.
2. ONLY HALF fill Dr.EpSUN Refill Tool with warm Magic Inkjet Flush (or correct color Ink if refilling with ink)
3. Then Holding Dr.EpSUN Refill Tool upright... cover metal tip with a tissue and expell any trapped air until ink appears.
4. Insert metal tip into circular ink outlet hole of upturned cartridge... until black rubber makes a GOOD seal.
Holding both securely...
5. Do NOT TRY TO FILL Instead. PULL UP on the plunger of Dr.EpSUN REFILL TOOL.
6. Air will bubble up through the Magic/ink whilst escaping from cartridge creating a vacum.
7. Now... Simply allow plunger to retract and the Magic/ink will automatically refill the cartridge for you.
8. STOP filling before the Dr.EpSUN Refill Tool is empty otherwise air will entering.
9. Repeat until ink cartridge is full.
How to FLUSH a BROTHER print head.
10. Place filled cartridge into printer and you are ready to print.
Use print head cleaning to prime which will also fill the ink tubes... then....
11. Print rectangles of the problem colour(s) using test sheets (see below) to prime ink.
As found in the manual, here are the print test sheets for printing rectangles depending on colour(s) with problem.
Just choose... Yellow, Magenta, Grey Tones etc...
PRINT TEST SHEETS FOR USE WITH MAGIC INKJET FLUSH
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Once prints appear to be normal simply replace the Magic Inkjet Flush with ink cartridges and continue printing rectangles untill flushed.
Hope it helps. If you need any further help Click Here then choose "Ask a Question"
Thanks
John P Bradley Tinteiros (Ebay)
Nov 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
Cartridge? problem
If you are using or have used third party generic ink cartridges or refilled ink cartridges, the Cartridge Sensor printed circuit board may have been damaged. We have found that some third party generic ink cartridges leak onto the ink cartridge sensor circuit board causing an electrical short of the ink cartridge sensors. The damage from the leaked ink results in the machine displaying NO CARTRIDGE because the machine will no longer recognize the installed ink cartridge(s). Genuine Brother ink cartridges do not cause this issue because of the unique design developed to fit specifically in the Brother products. As long as a Brother cartridge has not been refilled, the Brother cartridge will not leak.
Jul 07, 2008 | Brother MultiFunction Center MFC-440CN...
Above link great.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
Instructions on refilling cartridge for brother LC41CL cartridge
Do mix the ink with some glycerol to prevent clogging!
2ml glycerol (85%-glycerin alc. from drugstore) with 10ml of ink for C/Y/M and shake well (mix) before use. Mix 1,5 ml glycerol with 20ml BK ink.
Simply drill a hole into the brandname (O of brother) on top of the cart. Refill with 12ml for C/Y/M and about 21ml for bk.
You can leave the hole open.
Next time when cart is empty simply open scanner and refill without taking the cart out! ;-)
DO MIX THE INK WITH GLYCEROL!!!
Apr 03, 2008 | Brother MFC-5440CN All-In-One InkJet...
186 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
