Question about Apple Griffin Gport Ii Internal Serial Port Adapter Card Power Mac G4
G-PORT/G-5 COMPUTER WHERE CAN i FIND A G-PORT FOR A G-5 MAC PRO?
    New Friend:
  • 10 Answers
Do you mean in the Mac itself or on the internet?
Posted on Jul 30, 2013
My computer monitor wont start up
try pulling out the power plug to the monitor and then plug back in and turn on monitor.
I am assuming you plugged the DVI cable back in to the correct port on the monitor and Mac Pro.
May 03, 2016 | Computers & Internet
How do I connect my MacBookPro to my I Mac to transfer photos and music?
  1. Connect the Thunderbolt cable to the Thunderbolt ports on each computer.
  2. OR
  3. Connect the Mini DisplayPort cable to the ports on each computer.
  4. To change display settings, choose Apple menu > System Preferences, then click Displays on the primary Mac.
Oct 03, 2014 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
Intel Pro PC Camera CS430 Personal Web camera for mac
1 Make sure that your usb webcam is compatible with Apple computers.
2 Upgrade your software and drivers.
3 Uninstall older components if you have any.
4 Install the components you downloaded by double-clicking on them.
5Plug your webcam into the USB port on your MacBook Pro.
Mar 08, 2012 | Intel Pro PC Camera CS430 Webcam
I've got a BT HomeHub which works fine with a 4-port Ethernet switch to give me a small home network of 1 Mac Pro, 1 Laptop and 1 printer. I have an older Netgear RO318 Router - with 8-ports. But when...
When you use the older Netgear RO318 Router, make sure you don't use the WAN/Internet port, only use the numbered switch ports of the router.
Jul 31, 2017 | NetGear RO318 Router
Seagate Hard Drive Pro 500 GB not detected
You need to test it by connecting it to another computer. This is the cheapest, easiest way to test if it's working.
If it does not detect on another computer then you can get it replaced by seagate. All freeagent series of drives have a 5 year warranty on them, so your drive will still be under warranty.
However, bear in mind warranty will replace the drive but does not include recovering your data. If your data on the drive is important you will need to speak to either your mac specialist or a company specialising in data recovery who can assist you.
If however the drive works in another computer, then you have confirmation that it's only something on your computer that is giving the problem. You can try connecting to a different usb port if you have not already tried that.
Apr 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
MACBOOK PRO DAMAGED USB PORT
Hardware. Had a bad spill with a drop? Very unlikely you can have it fixed cheaply, but go to your local mac store and see if you can get it fixed.
Jan 27, 2009 | Apple MacBook Pro PC Notebook
USB Printer Problem
check usb cable working properly.reconnect it with other port then uninstall driver then reinstall.
Jan 03, 2009 | Apple MacBook Pro Laptop Computer with...
Can a macbook pro work with a hannspree 28" LCD monitor?
I cant see why not, On you TV you have incomming port called HDMI, on your mac you have an outgoing port called MiniDislay for DVI.
You can use that port whit an adapter to make it to a real DVI, the you need another adapter to reform the DVI to HDMI. It can be done, its a little bit tricky, but it can be done.
here is the spec on your mac
http://www.apple.com/macbookpro/specs.html
And here are the spec for yor tv
http://shopper.cnet.com/lcd-monitors/hannspree-hf289hjb-flat-panel/4014-3174_9-32915918.html#info-5
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 14, 2008 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Apple Griffin Gport Ii Internal Serial Port Adapter Card Power Mac G4 Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
