HDMI video + 6CH direct audio w/ Harman Kardon AVR 141
Here is the problem: I can choose between 3 HDMI sources HDMI 1/Coax 2 | HDMI 2/OPT 1 | HDMI 3/OPT2 I receive video signal from HDMI, but audio signal from 6CH Direct. If I choose this on the remote, it also drops the HDMI source. Then I have audio, but no video. Weird thing is, the manual says, I should do exactly this with a similar device (AVR 142) http://www.harmankardon.com/resources/Brands/harmankardon/Products/ProductRelatedDocuments/en-US/OwnersManual/AVR_142_OM%20(English%20EU).pdf Might it be somehow possible to setup a HDMI 1/6CH Direct ? Can somebody help me with this?
pazman
  • 81 Answers
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
Posted on May 10, 2008
SOURCE: direct source
I downloaded the manual from some site 5 min. after I posted and it was simple. Turn the reciever off, then press and hold the enter button while you turn it back on. It worked, no problem...
Posted on Dec 10, 2008
  • 5 Answers
SOURCE: harman kardon Audio Viseo Receiver shut down- no longer providing sound
as I understand it, these systems use a DIN plug and sometimes these DIN plugs can get damaged seperating connections inside of the plug itself, try testing these connection from the tips of each pin to the other end of the cable and see if you can find a connection for each pin. if so then you have eliminated that as the issue, also, if they are all good and you can get me a diagram of where each color goes, that would be great so I can help others with this issue in the future.
Posted on Feb 08, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
AVR 141 HDMI Video + Direct audio
Hello, please contact Onkyo at 800-229-1687 option #3 so that we can review your setup. Thank you, Onkyo USA
Apr 12, 2017 | Onkyo TX-SR606 Receiver
Harman kardon 2650 auxiliary ports 2,3,4doesn't work
if you are talking about the hdmi ports, 3 are ins and one is out, but I use the hdmi from player direct to tv, and use coax or optical connection to my receiver for the audio
Mar 23, 2013 | Harmon Kardon Harman Kardon AVR 2650 7.1...
Does the Harmon kardan avr25 have an hdmi output
Nope. You get one component OUTPUT (monitor) and two component INPUTS (Vid 2/DVD) but no HDMI video output.
If you can input and switch HDMI video directly at your display from your cable/SAT etc. you should be fine, just run all the audio through the AVR-25 through the coaxial/optical digital inputs, L/R analog RCA or the 5.1 direct inputs.
Feb 13, 2013 | Harman Kardon AVR 25 MKII
I just bought an Harmonkardon AVR 354 7.1 receiver and am having trouble hooking up the HK DVD 48, the Sony Bravia and the Hd cable box. The tv has four HDMI hook ups and the dvd has 1 and the cable has...
http://www.retrevo.com/support/Harman-Kardon-AVR-354-Receivers-manual/id/19547ci973/t/2/
I see only two potential HDMI sources - Cable and DVD. You have three possible inputs to choose from. BTW: Composite Video is also HD in an analog form. Keep it in mind for the future.
You have an HDMI Out for feeding one input on the TV.
Ponder why all the devices have separate (and multiple) high-end audio and high-def video paths. This is what I do...
NO signal ever benefits from multiple connections or 'hops' and it gets expensive zig-zagging a signal all over the room especially if it only passes through a device on the way to another one with no improvement. K-I-S-S is the word of the day. Run the BEST version of any signal directly from its source to the BEST electronics that will present it to you for consumption.
Sep 09, 2011 | Audio Players & Recorders
I have a harman kardon AVR 132 and have just purchased a Samsung UA55D7000. I am running HDMI from the sammy to my ps3 for video and then an optical cable from the ps3 to my HK for audio and im having...
Hi, You might want to run your ps3's hdmi into your hk, as I'm sure it has hdmi inputs. Using your hk as the audio /visual switcher may resolve this issue-and by the way the hdmi cable has audio built in. I hope this was of some help and thanks for choosing FixYa, good luck Prodzilla.
Apr 20, 2011 | Harman Kardon AVR 130 Receiver
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
How to connect the herman kardon AVR 260
I have a AVR 247 and a AVR 347 there is a HDMI output on the back this will go direct to your HD TV HDMI input. If you have a HDMI output on your SAT. box then run this to the receiver HDMI 1 input. If you dont have a HDMI output on your SAT. box, then you want to use the digital fiber optic output from your SAT box and run it to OPT 1 input on the back of the receiver. This will be for audio only from the TV but thats all you want anyways. Be sure to set your receiver to HDMI 1 OPT 1 for this option. PS. This is a very clean and nice sounding receiver the only flaw to these receivers are the amount of heat they generate even on very low volumes. You must get a 4 or 5 inch boxer 120 volt fan and set on top of receiver blowing down and plug it in the back of receiver on the switched plug outlet so it comes on when powered up. This will make your receiver last 10 times longer. i have had mine for 3 years now and run them very hard sometimes with no problems with this fan addition. Hope this helps good luck.
May 24, 2010 | Harman Kardon AVR 2600
Harmon/Karden AVR 230 Surround Sound Receiver
Use your remote to get into the Menu. Look for something called audio, or audio properties. In there you can choose your inputs (sources) and output choices.
On the remote itself, there should be a button called input, or source. That would be for things input to the TV.....such as dvd, vcr.
Apr 06, 2010 | Harman Kardon AVR 230 6.1 Channels...
Can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Dec 08, 2009 | Harman Kardon AVR 230 Receiver
Audio problems using a Playstation 3
First try ensuring that "OPT 1, 2, or 3" function is selected depending which one you are using on the H/K 146 (see manual for selection instructions). Next please ensure that the PS3 audio out set to "optical" (Settings/sound settings/audio output settings/digital out+DD 5.1). That should help.
Dec 05, 2008 | Harman Kardon AVR 130 Receiver
161 people viewed this question
 Grubhead
Grubhead
