Question about Proform PFTL79807 - 850 W/ Gamefit Elliptical
Proform 950 Adjustable Knob
Hi, Looking for an adjustable know for my proform 950. This part has been discontinued and I can't seem to find it anywhere on the net. Can anyone help me?
    Top Expert:
  • Proform Master
  • 12,223 Answers
Go www.fitness.manualsonline. com + www.doctortreadmill.com
and get it
GOD BLESS YOU
Posted on Jul 27, 2013
  • 12 Answers
SOURCE: proform vr900 recumbent tension not working
Here is a link to the owners manual. If this is correct the fix should be relatively easy
http://www.iconservice.com/pdf/PFCCEX01010.pdf
Gerritt
Serving the Twin Cities
Posted on Mar 13, 2009
  • 64 Answers
SOURCE: I lost my owners manual for my Proform 585 treadmill
Iconfitness.com
Posted on Jun 08, 2009
  • 13 Answers
SOURCE: Proform Crosswalk Advanced 525X
One possibility is the pulley in the front roller.The shaft that goes into the roller slips making the belt seem as if its slipping. To check it it requires tmarking both surfaces with paint and then see if the mark seperates.
Posted on Dec 01, 2009
SOURCE: Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Posted on Apr 18, 2010
  • 3 Answers
SOURCE: Have purchased a used Pro Form 900 Cardio Cross Trainer
If you can hear the adjustment motor running the problem could be related to two things:
1. Broken or stretched resistance adjustment cable.
2. Broken bracket for the magnet return spring.
If the resistance is on maximum all the time the second issue is most likely the cause.
Posted on Jun 19, 2010
Proform V650 Treadmill - Main motor does not turn
The board will most probably need replacing. Almost certain.
I repair this brand for the manufacturer.
Nov 06, 2013 | Proform Exercise & Fitness
Hello i have a proform crosswalk sport treadmill and when i turn the speed on it shows a reading for a couple of seconds, but doesn't come on. The incline works just fine. The motor will turn manu
adjust the REED switch see the diagram attached m clean it+test for open or faulty with DVOM, tight the connector very well,However try to RUN the software calibration and fix it. see the diagram attache too for speed sensor, adjust it and test it , clean it, and tight very well the connector.God bless you3_22_2013_4_18_58_pm.gif3_22_2013_4_19_19_pm.gif3_22_2013_4_19_33_pm.gif
Mar 22, 2013 | ProForm CrossWalk Sport Treadmill
Proform xp 70 stationary bike console is not getting power
IF BATTERIES ARE NEW THEN CHECK THE CABLE AND CONNECTION FROM BATTERIES TO THE CONSOLE.MAKE SURE ALL CONNECTION ARE TIGHT AND CABLES ARE NOT BROKEN,FRAYED,CRACKED,OR CORRODED LOOKING.ALSO MAKE SURE SAFETY DEVICES(KEYS,PINS,CLIPS) ARE IN PLACE .
Oct 13, 2012 | ProForm 70 Perspective Treadmill
How do you get the fuse out
1) see the block diagram attached. and proceed according with the logic sense.
God bless you
Jun 28, 2012 | Proform Crosswalk 2.0 XT Treadmill
My proform 3.8 treadmill isn't running at the
see the diagram attached adjust the speed sensor, clean, and tight the connector very well.
2) Run after you did the adjustment the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
May 01, 2012 | Proform Exercise & Fitness
Proform sports 1000 treadmill how to adjust the drive belt
HI,
Watch the following video to adjust the treadmill belt. All the treadmill's uses the same way.
Oct 09, 2011 | Proform Sport 1000 Folding Treadmill...
I have a Proform 910 and one of the front "legs" broke (adjustable for incline) and I am having difficulty locating the model let alone the part. Can you help?
PROFORM 910, model #PF91003
http://www.iconservice.com/CustomerService/manuals.do
This site will provide you with an owners manual/parts list and the phone numbers you need to order any parts required.
Dec 14, 2010 | Proform Exercise & Fitness
I have a ProForm 625 and the belt has started to slide to one side. How can I fix it?
Check the rear end cap. (end where the adjusting screws for the belt are) check for cracking around the screws they have more than likely broken through the end cap and are no longer adjustable.
Nov 10, 2009 | Proform Weight Loss 620 Treadmill - 24755
My 525x slips. Which part typicaly causes this?
This usually caused by a slipping drive motor belt. remove the hood cover, one screw in rear and 2 on the bottom. There will be an adjustable bracket on the drive motor. Good luck, Tim
Nov 05, 2009 | Proform Crosswalk 500 Treadmill
Proform PFTL79807 - 850 W/ Gamefit Elliptical Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
