Error f57 siemens WM14S794GB Front Load Washer
Hi, i have a siemens machine. the screen shows error f57. what does it mean? what should i do to fix it? thanks nava
  • nava yourvexel Aug 06, 2013
    i had a technition fixing the machine. f57 error means something is wrong with the motor module which is the electronic card thats in the back of the machine. part no. 679421 . or BSH9000511751.
    New Friend:
Bosch Logixx 8 Only 4 years old. Inverter Print burned out creating error F57.
Posted on Feb 09, 2015
4 Suggested Answers
  • 154 Answers
SOURCE: I have a siemens WM14S794GB washing machine and F23 is flashing
F:23 means that your machine is leaking and should be repaired. This is often a bad seal and if you are competent or know a friend who is they can inspect the source of the leak for you. Needless to say you should make sure that you unplug your machine before attempting any repairs.
Hope this helps you.
Posted on Jun 22, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: WHAT DOES F01 ERROR CODE MEAN AND HOW DO YOU FIX
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
F 16 AND F 63
F16 occurs when you try to start machine with door open or faulty door lock, F63 is a fault with control module
Mar 22, 2013 | Siemens WM14S794GB Front Load Washer
Need user manual in english
You can normally obtain manuals by typing into your search engine simply 'siemens washer manual'. You should then be presented by a number of sources from which you can either download for free or, in some cases, pay. I'm sorry but I do not know in your case and how much it might be!
John C
Feb 09, 2011 | Siemens WM14S794GB Front Load Washer
Sep 11, 2009 | Siemens WM14S794GB Front Load Washer
Siemens stops without going into the spin cycle
when it stops is there and f:XX error code on the display? were XX is a number.
Jul 18, 2009 | Siemens WM14S794GB Front Load Washer
F23 error
Your washine machine has sprung an internal leak and is leaking water into the base pan, this should be checked by a competent repair person.
Jun 14, 2009 | Siemens WM14S794GB Front Load Washer
My Siemens WM14S791ME Frontloading washing machine had a message displaying that the pump was blocked. I drained the water out of the front, and found a bobby pin and a coin. Now I try to turn the washing...
F:23 means that there is a leak into the basepan of the machine and it should be checked by a competent repair person as sson as possible, the boby pin may have jabbed a hole in somthing or more likly there is a bad seal some were on the drum.
Apr 13, 2009 | Siemens WM14S794GB Front Load Washer
Siemens WM14S794GB/01 Child lock problem
try hard rest unplug it 30 min then back in if then dont then in setting in book getout code u have to enter back in menu
Oct 06, 2008 | Siemens WM14S794GB Front Load Washer
Washing Machines Logo
4,337 people viewed this question
Top Washing Machines Experts
