Question about Hisense 0375625 Television
Update firmware usb drive - Hisense 0375625 Television
Update firmware lcd tv toshiba 32pb10e
How to Update Toshiba TV Firmware
  1. Plug a USB flash drive in to an available USB port on your computer and copy any files from the drive that you want to keep into a separate folder on your computer.
  2. Format the drive as a FAT32 file system. This erases all of the files currently on the USB flash drive.
  3. Click here to open the Toshiba Support home page.
  4. Click "Product Support" in the menu along the top of the home page. The Product Support drop-down menu opens.
  5. Select "Televisions" beneath Choose Category.
  6. Select your type of Toshiba TV beneath Choose Family. For example, options include 3D TV, LCD TV and LED TV.
  7. Select your Toshiba TV model beneath Choose Model.
  8. Click the red "Go" button to the right of the Choose Model section after selecting your Toshiba TV model. The product support page for that specific TV model will be displayed.
  9. Select the "Downloads" tab. If there are no downloads available for your TV model, either your won't be able to click the tab or there will be a message within the tab that says there are no downloads at this time. If this is the case, no firmware updates are available for your Toshiba TV. Check back periodically, as firmware updates are released as needed and aren't scheduled.
  10. If there is content in the Downloads section, look in the Category section for an item titled TV Firmware. If this option doesn't appear, no firmware update is available. However, if this option does appear, click the clickable link associated with the firmware. The TV Firmware Update and Release Notes dialog box appears. In this dialog box you can see the size of the firmware update file, when it was released, exactly what it addresses and more.
  11. Click the red "Download Now" button and save the file to your connected USB flash drive.
  12. Extract the contents of the ZIP file on the USB flash drive.
  13. Disconnect the USB flash drive from the computer after the firmware update file saves successfully to the device.
  14. Power on the Toshiba TV and then connect the USB flash drive to the USB port on the Toshiba TV.
  15. Wait a few moments for the "Firmware file is detected in USB" dialog box to appear on the screen. Select "Yes" to update the firmware. A progress bar displays on the screen. Be careful not to turn your TV off while the firmware is updating. The progress bar changes to a "Success!" message after the update successfully installs.
  16. Disconnect the USB flash drive from the TV and then restart the TV. After the TV restarts you can resume using the TV as you normally would.
May 22, 2014 | Televison & Video
Firmware update for LG bp125 gone bad
I ran into issues updating my BP125 to the LG_BD_7300M51.ROM firmware with a USB drive but was able to work around them. I think they occur because the BP125 expects the firmware to be in the upg_all subdirectory during part of the update. To successfully update, it needs to be in upg_all on the USB drive. If you update with LG_BD_7300M51.ROM firmware file in the root directory, the Bluray drive won't complete booting but a workaround can restore the Bluray drive. Here are the steps I took:
First, I tried to update with the LG_BD_7300M51.ROM file in the root directory on a USB drive. The update found the firmware, started the update, then powered off. I powered the Bluray player back on, and it said the update had failed and gave me an option to update using USB or Network. Neither worked with the LG_BD_7300M51.ROM file.
Second, I downloaded the BP120 LG_BD_7200M51.ROM firmware file, renamed it to LG_BD_7300M51.ROM, and put it in the root directory. The Bluray player found the firmware file, and I updated to it. That put the BP120 firmware on the BP125.
To update to the BP125 firmware, I renamed the LG_BD_7300M51.ROM file to LG_BD_7200M51.ROM and put it in the upg_all directory on the USB drive. The Bluray player then saw the update. I applied it successfully to get to the latest BP125 firmware.
Feb 23, 2013 | LG BP125 Bray Player
My Rx-V473 won't turn on
It couldn't start after an update. I found how to fix it on the product page : http://download.yamaha.com/search/detail/?language=en&site=europe.yamaha.com&asset_id=58063&category_id=16446&product_id=1643029&1375038490
Receiver doesn't power up after the update.
Error message appeared when confirming the firmware version.
Recovery method using USB method:
1. Unplug the AC power cable from wall outlet.
2. Insert the USB thumb drive which has the firmware data stored inside, into the USB port located on the front panel.
3. Press and hold the INFO key and keep it pressed while you plug the AC power cable back into the wall outlet again.
" USB UPDATE " will appear on the front display. Then, release the INFO key.
4. The update will start automatically.
5. When " UPDATE SUCCESS " appears on the display, firmware update is completed.
Power off the receiver and remove the USB thumb drive.
6. Confirm updated firmware version.
Oct 18, 2012 | Yamaha RX-V473 A/V Receiver Black
I updated my PS3 to OFW 3.55 (via USB), now i want to update the Kmeaw CFW3.55 (via USB) and get the error code 8002F997 (after 78% of PS3 copying the update). It does not work if i try the update in...
8002F997
- This error is caused by an issue with updating the PlayStation 3 firmware by USB drive. Ensure there are no problems with the USB drive. Download the firmware update to the USB drive again to ensure the firmware file is not corrupt. Try the installation of the firmware again. If all else fails, update firmware over the network.
Sep 14, 2011 | Sony Playstation 3 (PS3) Console
I have a Vizio Model E420VL and it gets into a state which the audio does not work (from HDMI input #1) and remote control processing in the unit also does not work. I had played around with the side...
hi,
It can be difficult to get things right on the first try. With that truism in mind, Vizio Incorporated includes USB ports on their televisions that you can use to load firmware updates onto the television. Vizio has released firmware updates only for certain television models, and the instructions for installing firmware updates vary slightly by model. To upgrade your television's firmware, you need to download and copy firmware drivers to a USB flash drive and then read and follow Vizio's specific installation instructions for your model.
1. Connect the USB flash drive to your computer
2. Click the "Start" button, and click the "My Computer" icon.
3. Right-click the flash drive, and click "Format" in the menu
4. Select "FAT32" in the drop-down menu, and click the "OK" button. Windows will format your USB flash drive with the FAT32 file system.
5. Open your Web browser, and navigate to the Vizio support Web site at www.vizio.com/support.
6. Click the "Select Your Product" drop-down menu, and select your model of Vizio television from the list. A new page will open that displays available downloads for your television
7. Click the "Firmware Update" link, and save the firmware update file to your computer.
8. Click the "Firmware Instructions" link, and read the instructions specific to your Vizio television model.
9. Right-click the file that you downloaded, click "Rename," and then rename the file to the exact name that is specified in the firmware instructions 10. Right-click the file, and click "Send to" > "E: USB Drive" or whichever drive letter corresponds to your flash drive. The firmware update file is copied to your USB drive 11. Right-click the "Safely Remove Hardware" icon on the right side of the Windows task bar, and eject the device from your computer
12. Disconnect the USB drive, and plug it in to your Vizio TV's USB port.
13. Follow the steps in the firmware instructions to install the firmware update to your television.
Only you can find is the problem with firmware by udating the frimware of your tv. ok
Aug 05, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
Hi I would like a little help to update the firware dvd blu ray bd 8002 Marantz tell me how should I do? thanks you.
Hello
Enter these sites for fudate your Maranz.
www.buyblurayplayers.com/firmware-updates/how-to-update-your-firmware
www.avforums.com/.../765663-marantz-firmware-updates-sr7002.html - United Kingdom
softwaretopic.informer.com/firmware-update-tool/
I'll ge you some hints also
Open the Internet browser and navigate to the Marantz.com website. Select "Products," then choose "DVD Players."
Select the DVD player you are currently using, then select "Manuals and Downloads." This lists all of the available updates for the Marantz DVD player.
Click the software update to download to your computer system
Plug the USB flash drive into a USB port on the computer, then click "Start," "(My) Computer," then double-click the removable device icon. A window loads with all of the files stored on the flash drive.
Click-and-drag the software update into the open window, then close the window, right-click the removable device icon and select "Eject."
Disconnect the flash drive from the computer once the icon disappears.
Plug the USB flash drive into the USB port on the rear of the Marantz DVD player, then power on the device. The software update will upload onto the DVD player. A prompt on the television screen appears once the update has finished.
Mar 20, 2011 | Marantz BD8002 Blu-Ray Player
Blue ray won't play Avatar?
There is a firmware update for the BD-HP22. I had the same problem with Avatar but after I installed the firmware update, it loaded and ran smooth. Use the USB flash drive that came with the player or any other usb flash drive to load the firmware update. Check the link below for instructions and update file from Sharp's website.
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
May 03, 2010 | Sharp BD-HP22U Player
How to update sharp aquos lc32d64u firmware. won't read from usb device to update S0803271 to S0909081. firmware name is "SAL2A217.UVP"
I was able to successfully update my Sharp's firmware by using a USB drive that was:1) formatted in (fat, not fat32)2) had only the one update file (.uvp) and3) a small USB drive (4gb - other posts said 2gb or less)
Feb 08, 2010 | Sharp LC-32D64U LCD TV
HOW DO I UPDATE THE FIRMWARE ON MY SAMSUNG LE40A557 ?
Hello Andrew
You can download the guide to upgrade Samsung LE40A557 firmware and the latest firmware file from here
You would have to download the firmware first on your PC and transfer the firmware file to a USB Drive and connect the USB Drive to the Wiselink USB slot behind your Samsung TV upgrade the firmware
Nov 23, 2009 | Samsung Televison & Video
My Numark iDJ2 won't update it's firmware!
I've tried it with a PC, I've tried it with a Mac, I've tried it with two different memory drives, and nothing will get it to update. Numark has a quality problem they need to address soon.
Mar 28, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Televison & Video Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
