Bosch Plena BGM/Paging System
Dvd stuck does not want to eject
3 Suggested Answers
SOURCE: stuck dvd in the bose 321
Try unplugging the Bose system, then plug back in and press the eject button. This works for me.
Posted on Jan 18, 2009
Brad Z
SOURCE: The system is stuck in mp3 mode and will not eject or accept a dvd.
If all else fails, unplug unit. Remove the left side plastic panel. It should slide towards the front of the device. Insert a long Phillips screwdriver in the round hole. Spin the plastic Phillips head nut inside clockwise for several revolutions. Eventually it will spit out any stuck disk in the machine.
Posted on Jun 05, 2012
How do I remove a stuck DVD?
It sounds like your problem isn't the dvd is stuck, since it seems to be spinning up, it sounds more like your ejection system has stopped working for some reason.
To fix either you are going to have to remove the outside case of the dvd player and expose the internal chassis. There are anywhere from 4 to 8 screws holding it on on the bottom and back of the unit, Make sure the dvd player is unplugged before you remove the cover.
Once you have the cover off, if the dvd is simply stuck, you should be able to see what the issue is; is it misaligned in the housing was it inserted incorrectly, are there in fact 2 dvds in the player, etc, etc. Gently remove the dvd and replace the case and enjoy.
If you can't see any reason for it to be stuck it may be the ejection system. The eject system will have a belt and sprocket system to move the tray or push out the dvd depending on the player. Make sure the belt is on the wheels correctly and that the sprockets mesh properly. If you can't see anything wrong try testing the ejection system with the case off.
Make sure you don't have any objects in or touching the dvd player, you don't want to short out any of the components if a screw fell into the dvd player onto the mother board, etc. Plug the dvd player back in, make sure you don't touch the inside and try to eject the dvd. Watch the ejection system and you should be able to figure out what is going wrong. Once you have figured it out unplug the unit and put the items back together. If you can see that something is broken then you will have to determine if you can have it fixed or if it wouldn't be cheaper to simply ditch that unit and purchase a new one.
Hope this helps.
Oct 12, 2015 | Televison & Video
BOSE LIFESTYLE 38 DVD PLAYER WON'T OPEN TO EJECT THE DVD
The DVD could be stuck inside the player or the drive may have failed.
Sep 08, 2014 | Bose Lifestyle 38 System
My BGM, back ground music used to work, now it does not. We use it only for music at our work stations. We press BGM for some music then toggle it off if necessary. It automatically shuts off if the...
Since a TD system BGM is just a single press "1" on an idle phone to turn on or off, I'm hard pressed to understand what you mean about BGM being a key. If you press "1" on a display phone and it says BGM On, and it doesn't work, go back to wherever the system cabinet is and look for the BGM port on the side of the phone system. It probably means the source is turned off or disconnected.
Carl
Aug 17, 2010 | Panasonic KX T7436 Corded Phone KX-T7436
DVD drawer will not open - stuck dvd inside
My only suggestion is to press and hold the eject button for a period of time (15 - 30 seconds). This might unlock the drawer. If not, I would contact Bose Customer Service directly.
May 15, 2010 | Bose Lifestyle 28 System
I have 2006 honda odyssey. i cannot use dvd system, because i cannot eject dvd. how can i eject dvd?
To eject the dvd from the dvd player you have to push the eject button on the dvd player, if the dvd is stuck inside the dvd player you have to get it checked by a service technician
Feb 27, 2010 | 2006 Honda Odyssey
Stuck dvd in the bose 321
Jan 06, 2009 | Bose (321GS) System
Dvd stuck in advent 10" dvd player in 2006 sienna.will play only so far but will not eject.
Sienna Minivan with a DVD entertainment system - rule nr 1 - Recorded DVDs would play but not eject, and then jam the system. It will require disassembly of the housing to reset power to eject.
Oct 04, 2008 | Televison & Video
Dvd try stuck
dvd tray will not eject...system show "opening" or "closing" but no action
Sep 19, 2008 | Bose 3 2 1 GSX System
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Two dvd's stuck in player
you cant get the system to open until repairing it but to get ur cds open ur system and take apart the place where the disc sets to start playing the movie
Dec 21, 2007 | RCA DRC8300N DVD Recorder/VCR
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
