Question about Dishwashers
Dw60ccx1 The LCD won't come on when my Fisher & Paykel DW60CCX1 dishwasher is turned on and there is 4 audible beeps. do the beeps just mean that the LCD is not working or does this identify a different fault?
jsrock516
  • 5911 Answers
SOURCE: dishwasher f1 problem on fisher paykel
All the information that I have found about this particular problem indicates that the "F1" error is a flood or overflow alarm. It's generally caused by a clog in the drain line and/or tub not sealing properly when closed.
If this is a drawer style dishwasher there is a lid in the equipment cabinet that must seat properly on the drawer when it is closed. If you place items in the dishwasher that are too tall for the drawer lid to seat properly, it will not seal and water will splash over the sides of the tub during the wash cycle.
Another common problem is a clogged or kinked drain line. Remove the drain hose and make sure it is not plugged. Check it at BOTH ends.
The alarm is activated by a float switch in the bottom tray of the dishwasher. Look to see if this is any standing water in the bottom tray. If there is any water, or signs of wetness, the alarm will not clear until it is dried out. I found a couple of recommendations to clear the alarm. The first involved removing the dishwasher from where it is installed and tilting it at a 45 degree angle to pour any standing water out. Another method is to dry the bottom out with towels as best you can, and then use a hair dryer to dry any residual water. I hope I'm on the right track with this and I hope this solves your problem. Post back if you have any further questions.
CAUTION: UNPLUG the dishwasher or turn off the breaker BEFORE servicing inside the cabinet.
Posted on Feb 20, 2008
  • 351 Answers
SOURCE: fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
Posted on Mar 20, 2008
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
SOURCE: Our Fisher & Paykel Washing Machine is not
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Posted on Sep 30, 2009
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
May 06, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel DD24DCTB6 top drawer beeps instead of starting
It is very likely the two problems are not linked. Use small quantities of power detergent (Finish works best) to avoid foaming. The foaming usually triggers flood switch and shuts dishwasher. If the beeping is constant then most likely the flood switch is triggered. But if you get one or 2 beeps when you press start, then it is likely some sensor in drawer is faulty. Usually the drawer close switch is not working.
Mar 18, 2013 | Fisher and Paykel Dishwashers
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Error code e9
I think I already responded to this. Your dishwasher should be under factory warranty.
Dec 22, 2012 | Fisher and Paykel Dishwashers
Fisher paykel dishwasher dd603 won"t turn on.
Is the problem with both the drawers or just one.
When you say - will not turn on - does it mean you get a blank display?
assuming mains power is turned on (no problem with circuit breaker), then it is likely the power board at the base of dishwasher (under the bottom drawer) is faulty and needs replacement. Make sure mains power cable is taken out when you work on the dishwasher.
Dec 11, 2012 | Fisher and Paykel 23 in. DD603H SS...
I keep getting a beep and believe it is a Fault Code
try turnning the unit of at the plug the the controll panel holde the program botton in and trun unit on try this on both draws
Jul 23, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Jun 21, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F 1 Error, blinking, beeping and will not stop even when turned off, so we had to turn the circuit breaker off to stop the noise.
You have a leak.
Either from the top lid seal or bottom lid seal. A s time goes by the water level activates the sensor causing the beep. It won't do anything until you fix the leak.
May 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
60 people viewed this question
Top Dishwashers Experts
