Question about Sony CDX-L350 CD Player
Error code 4 sony cdx-L350 CD Player - Sony CDX-L350 CD Player
SOURCE: CD RESET
to fix this problem you have to take the face plate off. There should be a small button on the middle-left side that sais "reset" on it. Get a ballpoint pen and press this button. Pop the face plate back on and play your CD and it should work no problem.
Posted on Jul 11, 2009
  • 1126 Answers
SOURCE: Hi , I have a Sony car Stereo CD player Model #CDX-L350
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C385125
Frank, try this link for wiring connections...looks like there are 2 different pin outs available here. Hope this helps.
Posted on Aug 23, 2009
Testimonial: "Thanks Very much , it was just what I was looking for , Thanks Again Chouch 3"
welcomejee
  • 10594 Answers
SOURCE: need a wiring digram for a sony xplod cdx-gt300 cd
Click Sony Support to dwonload installation guide of CDX-GT300
Posted on Oct 22, 2009
  • 27 Answers
SOURCE: Sony CDX-S2210 CD Player stuck on demo mode
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Posted on Jan 29, 2010
Nomodo4u
  • 863 Answers
SOURCE: need a wiring diagram to install cd player
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address2_bing.gif.
Here you go bud:
http://cgi.ebay.com/SONY-wire-WIRING-Harness-XPLOD-XR-CA430-CDX-MP30-sn6_W0QQitemZ200417888633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9d64979
Posted on Feb 23, 2010
Cd player reads error 04
The error 4 in most Sony stereos is an error that comes up when the laser pickup doesn't read the disc correctly. This happens most of the time because of a dirty lens in the laser pickup. If anyone smokes in the vehicle the smoke may be on the lens causing the error code. Try a wet type CD cleaning disc to see if it helps.
Dec 03, 2010 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
My Sony CDX-L350 CD Player's volume buttons dont react no matter how hard i press them, and i cant adjust the volume
Hi Kenny,
There is a manual reset that is used as a catch all remedy to handle symptoms of an unspecified origin.
It's located on the front of the unit, behind the front panel, directly behind the "ATT" button. Get a paper clip and press it.
Best regards
Aug 15, 2010 | Sony CDX-L350 CD Player
Aug 23, 2009 | Sony Car Audio & Video
E-4 error code
are you trying to mix a MP3 CD and a non MP3 player?
Mar 26, 2009 | Sony CDX-2250 CD Changer
Cd player gives me a error code 4
The player doesn't like the brand of CDR your playing. Try using just a CD burner instead of a combo CD/DVD burner2_bing.gif. Also use Verbatim Pastel brand, because the player recognizes these discs easier. Also, it wouldn't hurt for you to run a commercial disc laser cleaner through this thing to clean the optical lens. Burn music using Nero software because its easy and the best.
Mar 13, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
Son cdx m800 code contatcts
pleace send pin code cdxm800 sony
Jan 23, 2009 | Sony CDX-M800 CD Player
Set time clock on Sony Car CD Player CDX-GT100
Download User Manual of CDX-GT100 from Sony Support and got to page 4 for clock set procedure.
Thank you.
Nov 25, 2008 | Sony CDX-GT100 CD Player
Security code
Underneath the unit, solder all the blobs (4 of them) and it should by pass the code. FixMyRadio dot Net
Dec 04, 2007 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Sony CDX-L350 CD Player Logo
26 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
