Question about Sport & Outdoor - Others
The tractor runs fine everything works PTO three point loader bucket just won't move forward or reverse parked it one day and next time I started it it wouldn't move
mickey813
  • 472 Answers
SOURCE: 7264 cub cadet tractor hydralics
the starting problem may be a lose ground wire the other is probably the pump it sets on the back of the rear end its nothad to chang it just cost aroun 850 to 900 ya thats what it cost me the last time i done one
Posted on Nov 07, 2009
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
mickey813
  • 472 Answers
SOURCE: After stopping, tractor does not engage in forward or reverse
sounds like the by pass rod has been pulled out
Posted on May 08, 2010
  • 3911 Answers
SOURCE: husqvarna tractor won't go in
if you scroll through many of these posts, you will find that husqvarna make most frequently has a failed transmission. you have to replace the transmission and they are not cheap. if you can find the company which made the tranny, and the model, you can search for "new old stock" transmissions for sale cheap on eBay. the company name will be on the bottom or the top of the transmission. this being a "jelly side down " world you most likely will end up having to remove the transmission to see the top of it. there are only a handful of companies making them.
those mowers are actually made by MTD or AYP. not really a husqvarna product.
Posted on Jun 30, 2011
raineman_15
  • 273 Answers
SOURCE: 1999 FORD EXPERDITION TRANSMISSION WON'T MOVE FORWARD BUT MY REVERSE WORKS FINE WHAT I NEED TO DO
You can try shifting into manual 1 to get moving then once you get going shift the lever up into Drive. This should work, then drive it to a shop to have your ****** looked at.
Posted on Feb 08, 2012
Have a JD 300 with front loader. The tractor will not go forward when the tractor is started. It has a reverser and will go backwards immedictely when started. If the weather is real hot it will take...
Hi, don't know if you have checked this but anyway if you hydraulic oil filter is clean there may be another sintered bronze filter in the sump of the hydraulic tank this could be patially blocked> don't know this particular machine but if it is partially blocked it may be that you will clean that or there is air in the hydraulic system. Hope this is of some help.
Steve
Sep 29, 2013 | John Deere Muffler 1010 Diesel Tractors
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
My Lt 1050 Pto just stopped running and now it won't start
test the safety switch on the brake pedal and the pto switch
Aug 20, 2012 | Cub Cadet Garden
20001 vw jetta tdi automatic transmission problem
Ok , so you got home , parked it and when you started it up the next day and shifted it into reverse... backed out... and went to shift into drive , it stayed in reverse ?
Have you checked to see that the cable has not disjoined itself from the shifter to the trans.?
Are you able to engage Park?
Nov 10, 2011 | 2001 Volkswagen Jetta TDI
JD mighty mover tractor, 27MHz, 3 function remote 1. forward/reverse, 2. left & right, 3. loader bucket up/down Problem: no forward or reverse, front wheels turn left and right just fine, loader goes...
My son and I took apart the toy as we have the same problem with ours. The green terminal on the motor moves when we apply pressure to it and the motor speeds up considerably. It appears that a weak or bad terminal is the cause of loss of power. We are not sure how to maintain the pressure on this terminal.
We are going to put it back together and see if it works.
Apr 23, 2011 | RC John Deere Mighty Mover Dump Truck
JD 3320 tractor with error code 57
From what I can find, that is a 'timeout' error indicating the expected signals from the hydrostatic transmission are not being received. That would suggest that some of the wiring is still not repaired. Could it be the nice doggie pulled out a connector partially and you didn't notice? Make sure all connectors are firmly seated.
Some have seen this error code occur for the simple reason that the battery voltage was borderline low -- those computers are sensitive. So before you take it to the dealer, put the battery on a charger overnight to see if that resolves it.
Hope this helps. If so, please rate my solutions, thanks and good luck!
Jun 09, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
May 26, 2009 | Garden
Sport & Outdoor - Others Logo
603 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
