No picter but paper for black ink - Computers & Internet
  • 3,799 Answers
Motherboards don't use ink or paper. If you have a question, give as much info as you can, and then ask a question.
Posted on Jul 27, 2013
Mfc 6490cw print is lightly black so print is not good whot is probalem
Black is very difficult for an ink jet printer. If you are using the wrong paper, it even is more difficult. Please use paper made for ink jet printers, because the paper can absorb the fluid better so the pigment is more visible. There are also different ink's you can buy, but please if it really should be black, only use the brand own ink. Not a cheaper version. Professional printers even use different blacks for photo paper and for matte paper (and ink jet paper). Just to microbe how difficult it is to get real dark black on different media.
Sep 16, 2014 | Brother 1 Black Ink Mfc6490cw Mfc-6490cw...
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
How do i mix the colours on my stylus sx115 as i have run out of black but have the other 3 colours remaining?
Conserving Black Ink When the Cartridge Is Low (For Windows Only) The window below appears when black ink runs low and there is more color ink than black ink. It appears only when plain papers is selected as the paper type, and Text is selected as the Quality Option.
The window gives you the option to either continue using black ink normally or conserve black ink by using a mixture of color inks to create black. Click the Yes button to use a mixture of color inks to create black. You will see the same window the next time you print a similar job. Click the No button to continue using the remaining black ink for the job you are printing. You will see the same window the next time you print a similar job, and again have the option to conserve black ink. Click Disable this feature to continue using the remaining black ink.
Oct 16, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
It will not print in black ink even though I put a new black ink cartridge into the machine
Hello sir, good day, If you cannot print black ink on paper even with new cartridge on the machine, the cradle is dirty, the thing that holds your ink cartridge.
The ink flow is from the cartridge to the cradle then to paper, check the cradle, for proper cleaning.
Nov 13, 2009 | Computers & Internet
Compatibles wont work
Try this:
The HP all-in-one product will print black copies using both the color and black cartridges to create composite black in Normal and Best modes. This is necessary to create the correct grayscale shades.
  1. The color cartridge may be out of one color of ink. Perform the steps in the 'Colors are not correct' section above to verify that the ink cartridges are not low on ink.
  2. Verify that the correct paper type is selected in the Paper Type setting.
  3. Some photo paper has different chemical characteristics than Hewlett-Packard paper. The HP all-in-one is designed for use with HP Premium and Premium Plus Photo Paper. The photo paper, paper-type setting should be used with HP Photo Paper. For other paper brands, it may be necessary to use the plain paper or premium Inkjet paper, paper-type settings.
OR: The ink cartage you have may be defective if is a refilled or recharged cartage.
Jun 17, 2009 | HP DeskJet F380 All-In-One Printer
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
PRINTING ON BLACK PAPER
That would require a very special "white ink" print cartridge for your printer. The regular color ink cartridges won't do this, since they can only make the black paper "black-er" when it prints ink on the paper. You may want to ask the manufacturer (Canon) if they make a special "white ink" cartridge for that printer, or know of someone who does. Your only other option is to make a "negative" print image in Photoshop, or a similar graphics software application, and then PRINT the black ink on white paper... which will then leave everything you want to "print white" as an unprinted area on the white surface of regular paper. (Note: with such heavy printing you would want probably want to use a heavier grade of paper, such as 28# or 60#.) This will use a LOT of ink, but it may be the only way you can accomplish your goal. Hope this helps...
Aug 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
