Question about DeLonghi Magnifica 3300 Espresso Machine
Delongi magnifica error insert grounds container
4 Suggested Answers
SOURCE: infuser stuck up my delongi magnifica
I have a problem. I removed the infuser and the internal bracket is now in a "down" position and I cannot get the infuser back in. I need to know how to raise the internal bracket to its proper place. Any ideas?
Posted on Apr 10, 2010
wentlanv
  • 710 Answers
SOURCE: Delonghi Magnifica Rapid Cappuccino machine.
Hi Alan,
This posting is back on the unsolved boards again. I cannot see what anyone else has told you and I don't know what you have tried. So, I'm starting fresh....
If your control panel is not reading that you have inserted the container, then one of several things could be wrong.
I imagine you have already checked and cleaned all the parts involved and made sure that the lids are sealing and the container is seated properly. Clean around the door to be sure it closes securely.
If all of these things are in proper order, then it could be that the control panel has gone bad. Is there a reset button somewhere on your machine? Have you tried to go through the descaling/cleaning procedure and restart the machine?
If none of this works, I would suggest contacting DeLonghi to talk to a technician. Here is a contact page I got from the internet: http://www.delonghiusa.com/index.php?texts&pid=3
You may have already found the contact site, but if all else has been checked and found to be ok, I think that is your only recourse now.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 05, 2011
zippper808
SOURCE: DELONGHI PERFECTA SAYS INSERT GROUNDS CONTAINER WHEN IT'S ALREADY INSERTED
Just had the same problem after washing my ESAM5500.
Seems that some water hot on the switch that is triggered when grounds container is inserted.
My solution was removing the bottom panel (5 screws if I remember correctly) and disconnect the green wire from the switch (there are three wires - green, ping and blue). When the green wire is disconnected, coffee maker thinks that grouns container is inserted all the time - even if it is removed.
Posted on Oct 12, 2012
Delonghi magnifica raid cappuccino keeps on displaying insert grounds container when all clean and inserted please help can not get it to work
looks like the micro switch on the bottom might have some coffee grounds and prevent the grounds container from correctly closing
Clean with old brush and re insert.
If you still have a problem....it could be the micro switch
Nov 15, 2016 | DeLonghi Coffee Makers & Espresso Machines
Pre ground coffee
SORRY but FIXYA does not make coffee nor do we repair coffee makers . contact the manufacturer thru their website and ask tech support to assist
Oct 13, 2017 | DeLonghi Esclusivo Magnifica ESAM3300...
Delongi eam3400 machine. the water flow is good on the back of the machine but drips into the drip tray instead of flowing through coffee grinds/cup?
http://dl.mypdfmanuals.com/new/external_light.php I found the user manual, look in the troubleshooting section Kolbrub
Sep 17, 2013 | DeLonghi Esclusivo Magnifica ESAM3300...
Delongi magnifica EAM3400.n leaking water and coffee not flowing to cup
Hi i would start cleaning the machine with the cleaning stuff that is recommended. By the way from Electrolux comes a very good cleaningstuff.
Sep 17, 2013 | DeLonghi Magnifica Coffee Makers &...
Delonghi Magnifica Light B12 in manual states that
I had a problem where the machine would not operate and the water and grounds lights were on steady (red). After contacting customer support, they directed me to do a reset. This is done by disconnecting the power and holding down the ground coffee and decalcification buttons while reconnecting power. Then release the buttons and power on the unit. This revived my Magnifica from the dead, maybe it will work for you...
Nov 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Insert used coffee container this is what my
just take tray out refit bucket ..make sure theres no old coffee in the way vacuum old dust out of unitof machine... now refit tray and slam door ... bsc appliances 07779933829 postal serrvice too
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi EAM 3400 keeps saying "Empty Grounds Container"
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
Dec 19, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
New unit just won't work - keeps saying to insert brewer unit
These machines seem to respond to what their CS dept call "priming the pump." Turn on machine and after it has warmed up, turn the hot water valve or about 30-45 seconds. Shut it off and after a pause 30 seconds, repeat this process 2 additional times. Do the same 3 cycles in the steam mode. ( hit the steam button for frothing) Check openings  where coffee comes out with a small wire, ect., to make sure they are clear. It should work.
Mar 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi Magnifica 3300 Espresso Machine Logo
82 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
