I have a 2000 camaro ss shuts down when it warms up
I have a 2000 camaro ss with 70,000 miles the car runs fine untile it warms up to about a 180 degrees then just shuts down and will not start untill it cools down help
Air Filter-clean or replace
Clean MAF Sensor--CRC MAF Cleaner
Clean throttle plate-CRC Throttle Body Cleaner
Spark Plugs- replace every 70,000 miles
Check -for vacuum leaks on ALL ducting and hoses
Replace front 2- O2 Sensors-ones closest to motor ,every 100,000 miles
Have TPS Sensor --tested with an oscilloscope for opens
Check bypass hose, on THE water valve to the heater core.The watervalve may not be returning the water back to the front of the engine the back of the heads are running too warm,it has to circulate in the bypass hose or through the heater core,common for chrysler v8,s .Bypass the watervalve completely to see if it runs cooler. If not,try to find a better radiator more cooling capacity!
