Question about LG Washing Machines
Lg wd11020d door won't unlock after washing is finished
SOURCE: Door locked
After trying all the above, making sure that as much of the water has been removed as possible, you can always use the manual door release. This is located behind the soap powder tray.
Push to open as you would normally when adding more soap powder, pull the tray out as far as you can.
Press down on the yellow portion in the tray and this should enable you to then pull the soap tray completely out.
Once out you should see what looks like a small grey plastic circle with a rectangular hole (ideal for a screwdriver) turn this and your door should open.
Posted on Jun 22, 2008
  • 184 Answers
SOURCE: I pushed the 'pause' button
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Posted on Aug 08, 2011
Testimonial: "It worked, thanks!"
rickead1
  • 1998 Answers
SOURCE: Hi, I can't open the
I am unable to find that model number for your unit but I did find another that was close and is also an LG Tromm click this link http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28702783&pkw_=basket&model_id=5520802&NewWindow=1 you would have to remove the bottom panel the one that has the drain filter attached to it by removeing the screws that hold the panel in place. Once the panel is removed then you would reach up along the side that the door lock assembly is on and you will see and feel a cord with a ring that you would pull and then your door would open once you pulled this cord. In some units if you unplug the machine for 7 minutes this also causes the control to reset and sometimes this also causes the door to be able to open once the control is reset. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks Rick
Posted on Aug 16, 2011
emissionwiz
  • 75814 Answers
SOURCE: front loader washing machine door won't open
try unplugging the machine to reset it.
Posted on Feb 28, 2012
caroldon
  • 17129 Answers
SOURCE: my servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Posted on Jul 04, 2012
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Lg washing machine WM2277HW takes spells where door won't open at end of cycle.
try to replace the latch, go www.repairclinic.com and buy online.
God bless you
Jun 19, 2012 | Washing Machines
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Apr 28, 2012 | LG WM2455 Front Load Washer
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Door won't unlock
take top off reach down with flat head screw driver and pop open unplug unit first then replace door lock
May 13, 2011 | LG WM-2277HW Front Load Washer
I need a manual for my LG WD11020D front load washing machine
go here http://ebookpin.com/electronics/lg-washing-machine-owner-manual-wd13020d-wd12020d-wd11020d-pdf but after opening it do NOT try to scroll - it will crash. Instead go to menu and SAVE AS and then reopen from your local drive
Nov 02, 2010 | Kitchen Ranges
Washing Machines Logo
14 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
