Question about Ricoh Aficio AP3800C Laser Printer
Recoh AP3800C ERROR 543
I installed a new fuser oil and my printer stoped in mid run stating error 543 - turned the printer on & off as advised to no avail Do not want to send for a service engineer who charge a £125 to insert a reset code. Would appreciate any help
  • 62 Answers
This is an overheat problem and will most likely come back. you can press CLEAR-1-0-7-STOP buttons in sequence holding down the stop button when you get to it. You should see a service screen come up if you do this correctly. Go into the first button (i think it says copy). you should now see a list of buttons1 through 9 usually. look in the 5 & 7 buttons. You are looking for something that says FUSING RESET or it may say SC RESET.push that button and reboot the machine. If that doesn't work check ebay for a new fuser.. It will run you $125-$150 there verses $250 from a dealer.
Posted on Nov 16, 2007
    Problem Solver:
  • 8 Answers
PhillyCopiers.com - that's my answer. Give me your offer.
Posted on Nov 01, 2007
SOURCE:
My printer start showing error sc542 what to do?
SC542 is a heating roller warm up error. Most likely the fuser lamp has failed - a faulty sensor or board is also possible but not very likely. You'll need a new fuser, I suspect.
Jun 10, 2014 | Ricoh Aficio AP3800C Laser Printer
Fusing unit is not set properly
turn the printer off and reinstall the unit after it has cooled off (30 minutes). Then open cover B and D. Remove the fuser unit, then reinstall it properly. Close covers D and B. The error clears automatically if the fuser unit is properly installed.
If the error is not cleared, the fuser unit is out of order. Replace it with a new fuser unit.
Nov 19, 2007 | Ricoh Aficio AP3800C Laser Printer
I have been advised of an error message on an Aficio 3800 series printer. I am told they need an 'Oil Fuser unit ' but as far as I can see the machine uses a Fuser Unit OR an 'Oil Supply...
The fuser uses an oil supply unit, which is changed separately from the fuser itself. The fuser oil supply unit (400549) is what is required.
You will find the manuals and other sueful details about this printer here.
Jul 07, 2011 | Ricoh Aficio AP3800C Laser Printer
But how can i reset the counter after installing a new fuser oil unit
Press {Menu}.
"Menu" appears on the panel display.
Press {U} or {T} to display
"Maintenance", and then press
{Enter}.
The maintenance menu is displayed.
Press {U} or {T} to display "Color
Regist.", and then press {Enter}.
Press {U} or {T} to display "Fuser
Adjust", and then press
{Enter}.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 23, 2010 | Ricoh Aficio AP3800C Laser Printer
My Ricoh 388 is in need of replacing the fuser unit which we just replaced months ago and are very expenseive. Is there a way to fill the oil only in the fuser unit instead of having to replace the entire...
Unfortunately, on the AP3800C the oil supply unit is part of the fusing unit. However, you can purchase just the oil supply portion of the fusing unit and replace that (part #G0604022).
I'm not sure how much that would cost, but it's got to be cheaper than a whole new fusing unit.
Jul 11, 2010 | Ricoh Aficio AP3800C Laser Printer
Replace fusing unit error
Can you put the old fuser back, just to see if the message clears.
Mar 04, 2010 | Ricoh Aficio AP3800C Laser Printer
120.07 Service Fuser Error
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model C530dn, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Jan 04, 2010 | Lexmark C530dn Laser Printer
Error message - Reset Oil Fuser Unit Correctly
The fuser oil sits on top of the fuser and has silver contacts on it. Sometimes the contacts in the machine get bent. Turn off the printer and check the contacts and if bent use needle nose pliers to make straight again. Make sure the contacts on the fuser oil are not drity.
May 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh fuser oil replace message
That is not a good idea. The oil is kept track of by counting pages, not by a sensor that measures the oil level. The oil runs out and the machine can't tell and now you have ruined the fuser. Which cost a lot more than the oil tank.
May 26, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
412 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
