Question about Dryers
Thermal fuse on a sears 970-C88072-00 dryer
How to replace the thermal fuse?
  • 8 Answers
SOURCE: Dryer Thermal Fuse
air flow could be the issue or if your heater itself is grounded against the cabinet i think your unit is getting to hot check all your vent lines if you have good air flow check the heater try taking the vent totally off for a few cycles and see if the fuse blows agian
Posted on Mar 24, 2008
  • 177 Answers
SOURCE: Thermal fuse change on Kemore 970.c85042-00
First you need to know your dryer over heated and the thermal fuse tripped for a reason.
You will need to replace the thermal fuse, thermal fuses are there to protect the dryer. When you have the dryer apart clean all the venting and vacuum out the dryer. Look online for a parts supplier in your area, you will need your model and serial number to order the thermal fuse they are about ten dollars.
how long is the venting, does it exceed 20 feet, how many elbows. Make sure the outside hood is clean
Posted on May 08, 2008
  • 464 Answers
SOURCE: My 970-c85092 dryer only runs cold air. I'd like
not likely a fuse. check the heating element for a break. the thermal fuse will shut the dryer down completley. could be you need an upgraded thermostat kit for the heater assy.
Posted on Oct 04, 2009
ftw1952
  • 10319 Answers
SOURCE: Sears Kenmore gas dryer not heating up
Remove all duct work and inspect for lint trapped inside. If you get a very good handful the moister sensor shuts down the burner automaticlly until the vents are cleaned thoroughly
Posted on May 03, 2010
  • 44 Answers
SOURCE: Have replaced heat element, thermostat, thermal
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Posted on Nov 20, 2010
My Maytag 6400AYW dryer does not heat. Vent was clogged. I cleared but it still does not heat. Smelled metal burning prior to problem. Appears that I need to replace thermal fuse and hi limit ther
You are on the right trac.
The easyest way to check the thermal fuses is to follow the wires from the heater element up to the control board and put a meter across the thermal fuses, most dryers have two, you unplug the leads remvoe and replace.
Unplug before you start.
Check you model number again, and then go to the sears web page and you will be able to pull diagrams of the unit, I tried and you have an error
Dec 31, 2012 | Dryers
I need a thermal fuse for Kenmore Series 70 gas dryer. How and where is the fastest place to get one to replace it?
any appliance parts store will have a thermal fuse. I get all my sears stuff on line but that always takes a few days.
Apr 14, 2011 | Dryers
May 03, 2010 | Dryers
Oct 04, 2009 | Dryers
No Heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 21, 2009 | Kenmore 73952 Gas Dryer
No heat...replaced vent hose...still no heat. Model 110 72922100 Sears Kenmore 90 Series. Please advise.
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim. And please don't forget to give me your rating for my help.
Jul 12, 2009 | Kenmore Dryers
Kenmore 70 Series
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
Jun 04, 2008 | Dryers
May 05, 2008 | Kenmore 63942 Dryer
Dryers Logo
112 people viewed this question
Top Dryers Experts
