Question about Dryers
How to replace fuse in sears 970-c88072-00 dryer
Where are the fuses?
  • 177 Answers
SOURCE: Thermal fuse change on Kemore 970.c85042-00
First you need to know your dryer over heated and the thermal fuse tripped for a reason.
You will need to replace the thermal fuse, thermal fuses are there to protect the dryer. When you have the dryer apart clean all the venting and vacuum out the dryer. Look online for a parts supplier in your area, you will need your model and serial number to order the thermal fuse they are about ten dollars.
how long is the venting, does it exceed 20 feet, how many elbows. Make sure the outside hood is clean
Posted on May 08, 2008
  • 686 Answers
SOURCE: dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Posted on Mar 06, 2009
  • 464 Answers
SOURCE: My 970-c85092 dryer only runs cold air. I'd like
not likely a fuse. check the heating element for a break. the thermal fuse will shut the dryer down completley. could be you need an upgraded thermostat kit for the heater assy.
Posted on Oct 04, 2009
ftw1952
  • 10319 Answers
SOURCE: Sears Kenmore gas dryer not heating up
Remove all duct work and inspect for lint trapped inside. If you get a very good handful the moister sensor shuts down the burner automaticlly until the vents are cleaned thoroughly
Posted on May 03, 2010
heatman101
  • 43501 Answers
SOURCE: Dryer is BROKEN
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Kenmore 970 c85022-00
Hi, is there's still parts available for Kenmore Model # 970-C85022-00. This dryer was bought from Sears Canada. Thank you.
Oct 15, 2013 | Dryers
I have a sears Kenmore Dryer Model # 41784042500. In the Manual it describes my problem (drum turns but no heat) the manual says I need to replace one of two fuses. But when I call sears they have no part...
Hi ray7112....
Sometimes fuses are called by different names, check and see if they call it by any of these names.
1...Fuse
2...Thermistor
3...thermostat
4. Thermal cutout
Please take time to rate me
Aug 23, 2011 | Dryers
DRYER RUNS BUT NO HEAT.WHERE CAN THE FUSES BE ?MODEL NO 970-17802-20.SERIAL NO XE73210031.KENMORE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
Dryer is BROKEN
heatman101
Apr 30, 2010 | Kenmore 62602 Electric Dryer
Oct 04, 2009 | Dryers
No Heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 21, 2009 | Kenmore 73952 Gas Dryer
May 05, 2008 | Kenmore 63942 Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
