White-westinghouse wasc18gnpwd split type airconditioner
4 Suggested Answers
  • 81 Answers
SOURCE: my samsung split type airconditioner is shutting down.
This is an outdoor unit error. I would have the system serviced.
Mat
Posted on Jul 16, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: split type airconditioner wont cool
start by cleaning both the outside coil and inside coil. run the system and look for signs of frost at either coil. if you see some, you may have a low charge. check the fan to make sure you have proper flow the indoor coil.
Posted on Oct 11, 2010
hvac1960
  • 2133 Answers
SOURCE: SPLIT TYPE AIRCONDITIONER HORSEPOWER NEEDED
36 Sqmtr requires 1.5HP. Helpful?
Posted on Dec 27, 2010
The brand name is koppel split type airconditioner.model num.1ku536P7A.no remote control.i use the universal remote control chunghop.but not functioning.no code are listing..can you help me?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jun 08, 2016 | Universal Remote Control Televison & Video
I have a koppel split type airconditioner.my remote was deffective can i use a universal remote control chunghop.what is the code?
There is probably no code built into the Chunghop. If the Chunghop has a "Learn" function then you can teach it the commands using an original remote (hopefully you can borrow one).
Where can I buy a regas kit for my split unit airconditioner I live on the Gold Coast
I've never heard of a regas kit for a split a/c system. You need a declaimer, a vacuum pump, the designated refrigerant, gauges, and a digital scale. Evacuate the system, when system holds a vacuum, look up amount of refrigerant and type from mfg. tag on unit of spec book. Add specified amout of refrigerant and your done. If noy familiar with pressure on gauges you can use an amp meter to ensure unit is not over charged or has a restriction which would cause higher discharge pressure and therefore high amperage. Best to call a tech. Cheaper and safer.,
Jan 01, 2015 | Sanyo 33,000 Btu Ductless Airconditioner
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
F8 error
F8 on tamashi ac
Jul 03, 2010 | LG Heating & Cooling
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
How to insert oil in outdoor of split type airconditioner
You shouldn't have to add oil. The little bit that leaks out with refrigerant isn't significant. I would be more concerned about the leak itself. Has it been located and fixed. If not it will no doubt leak out again. Also do you know how much refrigerant to put in the system? Have you vacuumed the air/moisture from the system etc. Is the system totally flat or is there still some refrigerant in it? Let me know so I can advise you correctly.
Feb 23, 2009 | Cfm Daikin R410a Split System Air...
How to hookup Nintendo 64 to my 26" Westinghouse LCD HDTV?
You should know how to hookup the power, after that, you should have a second cord, one end goes into the N64, the other end splits up into 3 cords, one yellow, one red, one white.
Simple find the correct ports in your HDTV and plug it in.
Feb 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
