Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Comments:
Apr 03, 2009
- YES IT DOES! and don't YELL at me for trying to help. You may not understand the terminology, but EVERY fax machine ever built, uses what is called a scanner, and a scanner glass!
Sandmanmac is correct. There HAS to be a scanner element in ALL fax machines - If not, you may as well fax a blank piece of paper. The recipient will be expecting one as well. A tiny speck of dirt will cause a line for as long as it remains there - A dab of rubbing alcohol or glass cleaner on a cloth and cleaning the scan part eliminates the line - To test it - try the "Copy" mode. The same scan part is used to make copies with your fax machine. Just make sure you "keep it clean"! Len
Is it possible to send the same fax to a list of numbers on the Sharp UX-510? If so how do you do...
(More)
Is it possible to send the same fax to a list of numbers on the Sharp UX-510? If so how do you do it?
My sharp UX-P105 displays check paper jam, check cover, and check film. The last time when somebody...
(More)
My sharp UX-P105 displays check paper jam, check cover, and check film. The last time when somebody sent fax there were 10 pages, but we only received 5 because we did not know there were more and we change to mode phone. When we saw it have more pages we put paper and press start/memory but it did not print more and the display continue with it information. Would you help me to erase this check paper jam, check cover and check film? when I try to send others fax it does not work. Thank you very much
I'm new to this office which uses the Sharp UX 510 fax. Is there a way for it to print confirmation...
(More)
I'm new to this office which uses the Sharp UX 510 fax. Is there a way for it to print confirmation when sending a fax? There does not seem to be a user's manual on site Thank you.
