Question about Nokia 1110 Cellular Phone
Screen rotate right
Screen rotet
  • arpit jaswal Jul 27, 2013
    nokia1110screen rotet
Display on laptop screen
You may have inadvertently pressed the correct hot keys to change the display around. In the bottom right hand corner of the screen you may have an icon for your graphics. If you click, or right click you can get the properties up. You should be looking for something which refers to screen orientation ie from landscape to portrait or vice versa.
Feb 11, 2008 | Acer TravelMate 2300 Notebook
I have a ford explorer that show a sign of low oil pressure and it does not start what is the solution to this
Was the engine roteting? If yes. Check the engine oil levele if low add 2 liter,
Jul 13, 2012 | 2004 Ford Explorer
How do i turn my screen back the right way
How to Rotate a Computer Screen 90 Degrees
Perhaps you built your own monitor, and the screen is displaying at the wrong angle now that it's all set up. Maybe you installed a new graphics card or driver, and it appears something has gone horribly wrong. It's possible you're just being creative, and think it would be cool to lay your monitor on its side and still be able to use the computer. Or, most likely, your cat or kids pressed some mysterious key combination which rotated your screen for you, and you can't get it back. Don't worry; getting your screen to rotate 90 degrees is easier than you think.
1 Identify in which direction your screen needs to be rotated. There are four shortcut key combinations, and each will rotate your screen so that the top of the screen is at the top, bottom, left or right side of your monitor; you need to know which combination to choose. Say you are you trying to correct a mistake, and put the top of your screen back where it belongs--at the top of the monitor. Or you are trying to rotate your screen because you are using your monitor differently than most people do, and want the top of the screen to be at the left or right side of the monitor, or even upside-down.
2 Hold down "Ctrl + Alt" and the "up" arrow key if you want to return the top of your screen to the top of the monitor. "Ctrl + Alt + Left Arrow" will rotate your screen so that the top of the display is on the left side of your monitor, and using the Right Arrow will put it at the right side. The Down Arrow will turn your screen upside down if your monitor is right side up. Make sure you hold all three keys down long enough; the screen may go back for a moment as the screen is rotated.
3 Open your "Control Panel" if nothing is happening, and see if there is an option to "Enable Screen Rotation" under your Display options. If not, you may not be able to rotate your screen. This is especially common with older computers, as they have older graphics cards or integrated video If you have a newer computer, you may need to have the graphics drivers updated in order for the shortcut to work.
Tips & Warnings
If pets or children accidentally rotated your screen, consider finding a way to better protect your keyboard not just from accidental keystrokes, but from pet hair and kids' spills. A keyboard cover might be in order.
Dec 02, 2011 | Toshiba Satellite C655-S5068 Notebook
My screen is on sideways and i cant put it back the right way
Tips & Warnings
Dec 02, 2011 | Computers & Internet
The screen is staying upside down when it starts up
Press "CTRL + ALT + arrow key"
Arrows:
Left - Rotates screen to the left
Right - Rotates screen to the Right
Up - Rotates screen to back to normal
Down - Flips screen
Aug 22, 2010 | Dell Inspiron 1501 Notebook
Vibrating sound when the car is idling
chexk all the bearings in front,, or remove first hte drive belt and rotetes each pulley,,, feel the nois and the sound diff old ones from new ones,,, its probably one of those bearings
Aug 01, 2010 | 1999 Chevrolet Cavalier
Screen display is rotated vertically
Try out the following solution.
Step1: Right click on your desktop
Step2: Select [Graphics Properties...]
Step3: Select the [Display Settings] tab
on the right you would see an option for "Rotation"
Step4: Select the radio button with '0'
Step5: Disable the "Rotation" option if you do not want the problem to re-occur
Mar 06, 2010 | Computers & Internet
Finding the egnine timing gauge for a 2000 dodge intrepid
it does not have one it is done by the comp you can check with a dianostics machine but it has coil packs so there is no adj the timming the way you tring to do it
Mar 15, 2009 | 2000 Dodge Intrepid
Starter problems
you say nothing happens sort of need more specifics, does it attenpt to rotate the engine? does the starter click? are all of the wires in the correct spots on the starter?
Is there powerat the starter?
have you checked your fuses?
can you rotete the engine by hand?
Oct 15, 2008 | 2001 Pontiac Sunfire
Nokia 1110 Cellular Phone Logo
26 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
