Question about Dryers
I Have A Whirlpool CaBrio Dryer That Does Not Start Because ThE Start Button is brokeN. Model Wed 6400sw0 HoW Do I Fix That?
rickzilla
  • 706 Answers
SOURCE: Whirlpool LER5644EQ2 Electric Dryer that won't start
Regarding model LER5644EQ2, here is a link to a parts website complete with an assembly drawing and parts list. In all probability,you have a blown thermal fuse and that will need replacing http://www.pcappliancerepair.com/model-display.php
Item #23 on the drawing .. a quick test would be to ( with power removed or disabled) measure the resistance across the two terminals and it should not be an open circuit or it is blown. The drawing shows exactly where it is and the parts list shows the item number/ cost and where to buy a replacement. Hope this helps..
Regarding model number is YLEQ5000PW1, you may have the same problem with your thermal fuse.. the parts website does not show a detailed darwing of your model but it should be similar to the other one I've cited in the location and thermal fuse.. The link I am sending is for the parts list for your washer and the thermal fuse.. http://www.pcappliancerepair.com/model-display.php
Let me know if that isn't the problem and we can look at other ways to zero in on a solution..
Hope this helps...
Regards...
Posted on Sep 11, 2008
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
SOURCE: Whirlpool Cabrio dryer won't start - the "sensing" light is on
where are the answers on those stupid site
Posted on Oct 21, 2009
  • 767 Answers
SOURCE: Whirlpool Cabrio dryer problem
Hello my name is Heath the problem is the heating element is probably burned out and will need replace.
Posted on Apr 08, 2010
Jahn27
  • 1554 Answers
SOURCE: Whirlpool Cabrio electric dryer WED6400SWO. Start
Remove the three screws securing the User Interface board cover then using a flat-blade screwdriver, pry the two locking tabs out and unclip them then remove the User Interface board cover from the console.
Lift the encoder locking tab and turn the encoder counterclockwise as far as it will go the lift the encoder straight up so that the shaft slides out of the rubber console seal. Remove encoder from the console without flexing the encoder ribbon cable wires at the User Interface board or they could break.
Carefully pry the front edge of the user interface board up using a flat-blade screwdriver then pull the board forward and remove it from the console.
The new User Interface board can now be installed on the console by following the above steps in reverse order. Make sure the console rubber seal does not become dislodged when installing the encoder shaft.
Let us know if you need further advice. Please make sure you accept the most helpful or informative solution. Accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Posted on Jan 29, 2011
We need to take apart our Cabrio Platinum Dryer to get it down our stairs.
Whirlpool cabrio dryer repair - YouTube
? 5:22
https://www.youtube.com/watch?v=aIxL38nnOLU
Sep 22, 2012 - Uploaded by Michael Steiger
Whirlpool kenmore safety fuse dryer not lighting GE Maytag. ...Dryer Troubleshooting - Not Drying or Taking ...
How to disassemble a Whirlpool Cabrio dryer
washerdryerrepairhelp.com > Dryers > Whirlpool > Whirlpool Cabrio
Jun 9, 2012 - How to disassemble a Whirlpool Cabrio dryer. Dryers ... If you need to take the drum out, there's a panel that holds it into place similar to the Maytag Neptune design. ... we respect your privacy and take protecting it seriously ...
How To Take Apart a Whirlpool Dryer ' Appliance Aid
Dec 21, 2015 | Whirlpool Dryers
HOW DO i RUN DIAGNOSTIC CODES ON THE WHIRLPOOL CABRIO ACCUDRY DRYER
This unit has a belt switch ( W10411937) located on the motor frame, you should first check to see if the belt is not broken, or has not come off track. This can be done by disconnecting power and removing the toe panel to view inside the unit. Pleazer Appliance...
Dec 27, 2014 | Whirlpool WED5500XW Electric Dryers
Squeaking Cabrio dryer when running
The squeaking is due to the drum glides or as some people call them slides, being worn or broken. Easy fix and very inexpensive part
Mar 25, 2014 | Whirlpool WGD8800YW Cabrio Platinum High...
My start button on my whirlpool cabrio dryer is not working
there are several components that could cause two of them would be a broken belt switch and the door closed switch
Nov 24, 2013 | Whirlpool Dryers
Our Whirlpool Cabrio Elecetric dryer will not start. Model is WED6200SW1. We had just finsihed drying a load and put a 2nd load in, but it won't start. All the light come on. Could it be a sensor...
it could be that or it could be the start button, you can check the button by adding a jumper in the wires that go to it,, this should be done as a check and not left that way,, for safety
Jul 03, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dry won't start when button is pushed yes it has
Bad door switch, possibly. Wire slide connector on the door switch is loose, possibly. These are really simple to fix.
Apr 07, 2010 | Whirlpool WED5900S Electric Dryer
Whirlpool Cabrio Dryer Wont go past sensing light when I press start. The door is tightly closed and the filter is clean. It just won't even try to start it just just beeps once.
my dryer sensing light was on and dryer would not start, we replaced the sensor fuse and now it works the fuse is in back of dryer close to the bottom on the left hand side very easy to replace cost $11.00 by the way don't call whirlpool they have no clue, wanted to send repair man out to fix it.
Nov 04, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a cabrio dryer and it will not start. It
control panel is bad, use your warranty and get it fixed for free since it is only 2 weeks old
Jun 15, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryers Logo
18 people viewed this question
Top Dryers Experts
