Question about Danby Heating & Cooling
Dac 8000 air conditioner
There is no drain on the unit and it has filled up as high as it can and no is spitting water into the house. The fan also makes a much louder noise than it did. I tipped and drained it and am now letting it dry before turning it on again. is there somewhere safe to drill a hole in the bottom to allow for drainage? Thanks.
  • 334 Answers
SOURCE: I have a portable air conditioner and the water
I would suggest putting a condensate pump in the reservoir, find the tube that empties the water into the reservoir and direct that into the pump. You can run tubing from the pump to a sink or any other drain in the house that is convenient. Putting the pump inside the reservoir is a safe guard in case the pump fails, the water will fill and turn the unit off instead of flooding the floor. It would actually probably trip your breaker once the water hit the voltage on the pump but always better safe then sorry. Check out these pumps at amazon, you don't need anything fancy.
http://www.amazon.com/gp/product/B000UVUW6Q
Good Luck
Posted on Jun 11, 2009
SOURCE: condensation buildup
Make sure the unit tilts towards the outside. If it's installed level or tilted toward front it will not drain properly.
Posted on Jul 14, 2010
  • 2468 Answers
SOURCE: Does Whirlpool air conditioner #
theres one near the back side on the outside part,they get plugged with bugs,leaves,debris,etc.,when its shut off look underneath and there is a drain hole on the bottom or on the rear ledge on either corner or both rear outside corners,make sure the unit has a slope toward the outside so most of the water drains there too,you can use a short piece of wire to clear these drain holes,if they are dirty enough you may need to unplug the unit and use a garden hose to dilute the debris so it flows out the drain holes
Posted on Aug 04, 2010
  • 5 Answers
SOURCE: I have a Kenmore Air Conditioner Model No.
Make sure the filter and coil behind the filter are not dirty (I am sure you did that already) as this would cause icing and excess water build up. There may be a steel or plastic plug in the bottom rear of the unit. If not, I have drilled a hole in the very rear right or left side of some to help drain the water, but you need to be sure that nothing, nothing at all is on the otherside where you drill (No wires, no tubing, no compressor, etc,) as you will damage the unit. If it is a newer unit under warranty call the manufacturer as newer units disipate the water in the exhaust air and it may be malfunctioning or it may just be extremely humid ouside and the unit is struggling to disipate the water.
Posted on Aug 07, 2010
cool78259
  • 228 Answers
SOURCE: My frigidaire air conditioner is
The tray that holds the condensed water from the evaporator
may be clogged, it may be clogged before the cleanout hole,
where the tray joins the pvc, if this is the case you may have to
power down your ac unit, there is a panel on your heater unit
that you will have to access to expose the evaporator coils and
you will see the tray where the condensation builds up and flows
thru a pvc pipe to go outside. also make sure that the pipe going
outside is at a slope so that the condensation can flow and not
clog the pipe. make sure that water can flow from the tray thru
the cleanout hole. once you correct the problem. you need to reseal all the seams with duct tape or metalic tape, you can purchase at most hardware stores, to make sure their are no ac
cool air leaks other than thru your ac vents. good luck!
Posted on Jul 30, 2011
My air condition window unit is spitting water how do I get to the drain line to clean it?
Hello, the drain line is usually located under the unit on the condenser side. If the unit does not have a drain then the unit is not tilted back enough to allow the condensate to be picked up by the condenser fan and splashed on the condenser to evaporate.
Jul 02, 2012 | Haier hwr10xc6 Air Conditioner
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
(Tilted) Plasmaire spits water into room....
What your problem is is that water coming back into your face is condesation. Appearently there is a clog preventing your condensation water from draining out the back side of the a/c You can remove the a/c from it's sleeve, take it outside and with a pump sprayer (Type used for spraying insecticide) filled with water spray around the base of the a/c where the condensor coil sits (you should see a small drain channel in this area) If this drain channel is clogged water will back up and the squirrel cage will pick it up throwing it out into the house.. Good Luck on your repairs
Dave
Sep 03, 2009 | Kenmore 76100 Wall/Window Air Conditioner
Droplets of water are coming from the vents and it's making a noise like something is rattling around inside. What could this be?
The problem with this unit is that the evaporator, or the part of the air conditioner that 'creates' the colder air is not draining correctly. Pertaining to a window unit, it needs to be installed correctly with the correct amount of tilt toward outside, to allow the evaporator condensation water to drain. You may also want to check to make sure there aren't any plugged drain holes in the air conditioner housing.
The rattling you hear is most likely the blower fan spinning against the held water inside the unit.
I hope this helps! :)
Sep 01, 2009 | Heating & Cooling
New LG 8000 btu a/c units are rusting
I have a similar situation with 66 a/c units in my motel. The problem is the drain valve in the back of the unit (near the compressor) does not function properly. It is supposed to open when the water temp (laying in the bottom of the unit) gets to 50 degrees cusing the drain valve to open and let the water out. The problem is the water never reaches 50 degrees when the outside temperature is in the 80's. So the water sets in the units. The fan sprays the water over the fan motor, heating element and inside the chasis causing it to rust from the inside out. I have notified LG and they are investigating it...... Amana has the same problems with their units which use the same drain valve and they have removed the drain valve in several motels in the area.
I would suggest removing the drain valve or wedging something under the little round plate so the the unit drains. Also make sure your A/C is tilted properly so the water runs to the back of the unit and drains.
Aug 19, 2009 | LG Electronic Window Air Conditioner
Window unit just started spitting a little water and making a noise like when something is too tight a fit, a rubbing noise. just started minutes ago. it's raining but, what could of happened?
Make sure the window unit is evenly placed inside the window frame.Just a slight twisting of the housing will cause the fan blade to scrape the housing. Make sure that the fan blade has no come loose from the fan motor shaft if that does not solve the problem. Also make sure the window unit tilts slightly downward so that any water from the condensate produced inside the home on the condenser coil can drain down the slope to the outsidelike the way explained. I have also seen units that were positioned correctly but the drain trough is blocked and will not allow the water to drain outside the house. Let Me Know, Thanks, Sea Breeze
May 15, 2009 | Haier hwr10xc6 Air Conditioner
Window unit spitting water
Check to make sure the drain holes are free from debris. The drain pan not draining causes the spitting and the fan is blowing out the water. Using a metal rod or hanger, gently clear all holes in the bottom of the unit. Prepare to get wet!
Jul 30, 2008 | Heating & Cooling
Split Unit Spitting water
Do you live in an area of high humidity? This could be your problem. The water that is coming off the evaporator and draining to the outside pan is building up and picked up by the condensor fan and consequently blown by the fan inside. If this is the problem the fix is to drill a hole in the pan to permit the water to drain from the pan. Be careful as to where the hole is drilled so as to not damage any component of the a/c. I would suggest at least a 1/4 inch drill bit be used to make the hole.
May 26, 2008 | Friedrich QuietMaster RS10J10 Air...
Heating & Cooling Logo
35 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
