Akai plasma tv picture starts vibrating then horizontal lines take over the picture
    Top Expert:
  • Televison & ... Master
  • 75,304 Answers
Y-Sustain should be checked.
Posted on Jul 27, 2013
SOURCE: plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Posted on Jan 01, 2009
  • 5 Answers
SOURCE: rolling horizontal lines on the display of my plasma tv
if u r connected to an ant. it is due to poor signals from the ant so get a booster or amplifier for the ant.
Posted on Mar 05, 2009
mbelectronic
  • 147 Answers
SOURCE: Red & Blue Horizontal lines in all imputs except HDMI
replace the main digital pcb.
Posted on Jul 17, 2009
boltthedog
  • 24 Answers
SOURCE: my samsung plasma has horizontal line across middle of picture
loose wire check connections
Posted on Sep 19, 2009
  • 1039 Answers
SOURCE: I have a horizontal line going across the picture of my tv.
The panel is bad and will need to be replaced.
Posted on Dec 06, 2009
Shadowy horizontal lines on plasma tv
Would have helped if you posted the make/model of the TV as well.
Apr 09, 2016 | Televison & Video
I have akai 2201 television set when i start the tv there comes a horizontal line on the screen with no sound & picture kindly gudie
IT IS VERTICAL OUTPUT SRAGE FAULTY. FIRST CHECK SUPPLY VOLTAGE 18VDC. THEN CHECK OUTPUT VOLEGE 15VDC.IT IS UPNORMAL FINALLY CHANGE VERTICAL OUTPUT IC.BEFORE CHANGING IC CHECK ALL THE COMPANENTS IN THE VERT.STAGE
Aug 02, 2010 | Akai Televison & Video
My AKAI PDP4273M 42" Plasma has thin horizontal lines that flicker across the screen and then the picture jumps and flashes red and green distortions on the screen acts like interfearance of some sort if i...
This sounds like a loose solder joint, or overheated component. I know this may sound like a **** question, but have you tried tapping the TV to see if it goes away? If it does, you will need a tech to re solder the loose component. I have also seen this type of line and color bleed problem, believe it or not from poor cabling or loose connections.
Mar 09, 2010 | Akai PDP4273M Television
Shaky picture AKAI PDP4298ED1
THERE MAY BE SOME CONDENCER LEKAGE SOMEWHERE IN THE HORIZONTAL SECTION
Mar 23, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Picture on AKAI 54 inch HD ready tv is not square.
akai is not a good brand of tv to start with they seem to have alot of problems and finding parts is impossible to do
Oct 16, 2008 | Akai PT5598HD 55" Rear Projection...
Video flickering
Horizontal lines are either caused by the main logic board, a dammaged screen or by the main x and y drivers. Hard to determine which one it is, but somthing is getting hot which is causing the problem. My guess is the main logic board.
Apr 03, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PDP4294 - Snowy, pink & green picture
It is most likely a problem with the tuner, I would contact the place you purchased it or your nearest repair shop.
Feb 07, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
