Question about Garden
Homelite ut20706 primer bulb replacement
  • 115 Answers
SOURCE: primer pump rotten need replacement show parts page
The hoses run through a hole into the gas tank, they are fitted with a filter inside the tank. Drain the tank, and manipulate the hose end to where you can grab it throught he filler hole, Remove the filter, run new gas lines into the tank and through the filler hole to replace the filter, reattach to the carburator. The primer bulb should have 4 small screws attaching it to the carburator. Remove the screws, place in new primer bulb, and you should be back to trimming asap.
Posted on Jul 06, 2009
  • 6 Answers
SOURCE: looking for a primer pump for Homelite htc12 tiller
Hi, I live in cedar rapids, Iowa. I just bought a primer bulb for my htc-12 homelite tiller. You should be able to order as many as you need, but I don't have the part #. Find out what the part # is and call this # 1-319-393-0443. They have 2 sizes, the bigger one is for the chain saws, the small one is for the tiller.( they have both) Carefully pry the plastic band off the primer bulb, press the new bulb through the band, then go get a tube of permetex weather strip adhesive ( orange box, black adhesive). Don't buy any other brand!. Lay a thin bead around the base of the bottom of the ring, press into place and let dry for a couple of hours. This adhesive works on almost any thing, and is not affected by gas, oil, or anything.
Posted on Mar 31, 2010
SOURCE: broken primer bulb
home depot has a fuel system rebuild kit that includes bulb, filter, hoses all for less than 7 bucks.
Posted on May 06, 2010
goldenglove1
  • 144 Answers
SOURCE: Replace a primer bulb on a Homelite Mighty Lite
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
Posted on Aug 12, 2010
rycgl
  • 1545 Answers
SOURCE: Where to find a replacement primer bulb for
Here is the part you need for your Walbro carburetor.
http://www.ereplacementparts.com/search_result.php?type=search-part&q=01201&manufacturer=Homelite
Posted on Oct 15, 2010
How do I figure out which primer bulb for the homelite ut20706?
Frank most primer bulbs are Universal. The top unscrews and the new one fits under the ring.
Nov 23, 2013 | Homelite Garden
How do i remove the primer bulb on my homelite mighty lite 26cc blower
The primer bulb should be attached directly to the carburetor. There will be a plate with 4 screws, once on each corner, which you will have to remove to get the primer bulb off of the carburetor. You can find replacement primer bulbs at PartsBuggy.com.
Sep 29, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a handheld blower/vac: The primer bulb is new and will not pump fuel,not even fill the bulb. I checked the fuel lines to make sure they were correct.(homelite)
I was working on a neighbor's homelite chainsaw and I replaced the primer bulb, it was not intuitive, and I hooked up the lines backwards. Also if you are replacing the primer bulb, maybe you have old fuel lines that are deteriorating and need replaced. Did you check the in tank fuel filter? If it looks dark, it may be time to change it.
I hope this helps get you going again.
Sep 01, 2011 | Homelite Consumer Products MightyLite...
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Dec 21, 2010 | Homelite Garden
Replace a primer bulb on a Homelite Mighty Lite 26cc trimmer
Aug 12, 2010 | Homelite Mighty Lite Lawn Trimmer
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
Feb 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
