Question about Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer
How to use the dryer?
Hi I would like to know the temperture & time to be used on my dryer to get ready to use cloathes.I have lost my user manual. Thanks
  • 183 Answers
Even the manuel cannot answer this question, it is dependant on what fabrics you have in the dryer, how large aload you put in, the spin speed of your washing machine or how much water is extracted by the spin,suggest that you experiment with a small load and intermittantly check as the dryer progresses, there is no definitive answer, sorry. Regards Advisor
Posted on Sep 01, 2007
  • 4 Answers
This should be simple and will not need a user manual. For silk, polyester, nylon, wool and delicate fabrics that dryer setting knob should be set to "Less Dry" or similar settings and then press on the start knob. For cotton, use the "More Dry" Setting. Now, these settings may vary between models. I am more familiar with the Whirlpool ones. Gook luck.
What year was Kenmore dryer 110.66112500 made
Carter,
You can go to the following website and enter the info requested at the bottom of the page and it will give you the date of the dryer. You will need both your model & serial numbers. The manufacturers do recycle their model numbers about every 11 or 12 years, so you may get a range of dates.
Appliance411 Service How old is my appliance Age finder date of...
One thing that you can check, look at the exhaust hose coming out of the back and make sure that it is not kinked in any way and if you can, pull the dryer out and make sure that the hose is clear of any blockage. Usually when you have longer drying times it caused by poor air flow.
Jul 24, 2015 | Kenmore Dryers
I have kenmore he4. My cloathes dont dry completley. My flame ignites for 20 seconds then goes out. Then this behavior continues about every 5 minutes throughout the cycle. Ad the cycle continues the...
I still say ur safety gas valve and coils are bad SORRY NOT ABLE TO HELP MORE WHEN U CHECK the ceramic igniter it could test good meter wise but yet be bad mechanically which would also do what ur experiencing if it was going bad
Mar 29, 2015 | Kenmore Dryers
What temperature should my tromm lg dryer be to dry a load of cloathes
the normal temp cyc's from 140 to 210 but if falls below 120 for any length of time something else is up in the normal cotton selection.
Feb 27, 2011 | Dryers
When i put my oven on to 350 it takes a long time to heat, then the beeper beeps to let me know the oven is ready BUT it is not at 350. I have an oven temperature gadget and it shows it is at 275. ...
Standard oven thermometers use a bi-metal coil, which is slow to react. When we test oven calibration, we use digital thermometers with a remote temp probe which are MUCH more accurate and MUCH quicker to respond to temperture changes. If your bake times are significantly longer or shorter than the recipes state, have a service technician test it.
Feb 19, 2011 | GE Kitchen Ranges
It is not drying and the temperture knob is not turning
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
cvnc
Apr 11, 2010 | Roper REX4634KQ Electric Dryer
Clothes not drying
The temperture sensor is at fault. It shuts down before the temperture is hot enough
Feb 02, 2010 | Frigidaire GLGQ2152ES Gas Dryer
Slow drying time
very simple, do this test, take your vent hose off the back of your dryer, now dry a load of clothes, if it still takes a long time to dry, then you may need to replace your thermastats, if it works better, your vent hose was pushed in, or smashed or the vent from the wall to the outside is clogged.
thanks Whites appliance repair
Sep 07, 2009 | Kenmore 659 Electric Dryer
Lg washmachine tromm, does not dry completely the cloathes
is this the washer and dryer in one machine
Jul 01, 2009 | Dryers
Dryer stops shortly after being started
Dust has gathered around the thermostar wtich tells the machine when the cloathes are dry Remove the dust The thermostst is located inside the door on the right hand side it looks like a small nail sticking out
Feb 11, 2008 | Dryers
Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer Logo
177 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
