Question about Dryers
Maytag MDE3500AYW dryer
How to install a 4 prong power cord to mate with 4 prong outlet
  • 262 Answers
SOURCE: 4 prong dryer cord to 3 prong dryer cord
YES NEUTRAL GOES IN THE MIDDLE L1 AND L2 WHICH ARE HOT GO TO THE LEFT AND TO THE RIGHT LIKE THE CORD IS LAID OUT
Posted on Dec 11, 2007
Master_Tech
  • 770 Answers
SOURCE: changing four prong dryer to three prong outlet
use the ground on the machine.....There are 3 wires on the terminal block if you notice there is a grounding strap off the center post this will act as your ground to the machine back in your panel box the center post leads to ground anyway the other 2 are hot leads (240vac) use the 3 post you will be fine. you will be grounded let me know if you have any problems
Posted on Feb 19, 2008
jsrock516
  • 5911 Answers
SOURCE: changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. Let me know if you still have questions.
Posted on Nov 11, 2008
frcs68
  • 1605 Answers
SOURCE: How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Posted on Apr 23, 2009
Controlfrk
  • 304 Answers
SOURCE: need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Posted on Oct 04, 2009
Change Maytag dryer 4 prong plug to a 3 prong plug
The cover on the back should only be held on by screws and are usually easy to get off. Have you checked for these?
May 04, 2012 | Dryers
Can i change a dryer with a 3 prong cord to accomidate a 4 prong outlet..if so, how?
Yes, no problem. here are the pictures. You will need the proper cord.
The first picture is the standard 3 prong, the second is the 4 prong version.
Apr 14, 2010 | Maytag SDE3606A Electric Dryer
How do I connect the a 4 prong power cord
Four prong dryer cord connections to dryer:
- Red to far-left or far-right screw on dryer (doesn't matter which side)
- Black to screw on opposite far-side on dryer
- White to center screw on dryer
- Green to dryer grounding screw
Any questions, please let me know.
Oct 02, 2009 | Maytag Dryers
I have a Maytag dryer with a 3-prong plug. My new
The following link explains how to convert a 3-prong cord to a 4-prong:
The main difference is how the Neutral (WHITE) and Ground (GREEN or BARE) wires are installed. In a 4-wire configuration, the neutral and ground are INDEPENDENT of each other and are not connected together.
Read through the link and let me know if you have questions. I hope this helps you.
Sep 02, 2009 | Dryers
Can you tell me how to hookup the three wires of 3 prong cord to the back of dryer that came with 4 wires(4 prong)? Which one goes where? I only have 3 prong plugs at my house. Thank you.
The following link explains how to connect a power cord to your appliance:
Now keep in mind, some newer appliances REQUIRE a 4-prong plug in order to work properly. You may consider having a four-prong outlet installed to accomodate your dryer.
You can try these steps by referring to to section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, please let me know. I hope this helps you.
Jul 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
4 power cord to a 3 power cord
You can take off the cord and put a three prong plug for the dryer it will come with 4 wire that connect to the dryer the one that is not coded is the ground wire. when you take off the one you have now it should have a ground connected to it. Or you can get a new receptical to match the one you have now but it would be more expensive. Hope this helped. If not let us know and thankyou for asking.
Mar 16, 2009 | Maytag Dryers
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
Changing cord from 3 prong to 4 prong on frigidaire dryer
Nov 11, 2008 | Frigidaire GLER331A Electric Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
