Question about Samsung SCX 4521F All-In-One Laser Printer
Scanner not working
I have installed the drivers that comes with the SCX-4521F. Everything works perfect except for the scanner. I always get the same message when I try to send from the scanner to computer error during scan restart program and printer. I have re-installed drivers and etc. I am working with windows XP pro. When I try with smartrue 4 I get the same message plus can not open device. I was looking at one problem posted here. Where it says I have to unlock the scanner? I can not find anything to unlock. Please help me out I have been trying to find a number for samsung support and no luck either.
  • khansen Aug 30, 2007
    I will try to download new drivers.
    In my control panel I can only see fax and printer no scanner available?
In order for scanner to work, you need to use the usb interface(port), not the parallel port. DYi
Posted on Oct 08, 2007
    Sergeant:
  • 390 Answers
Samsung can be cheeky with support i have found and not as helpful with tech help. Instead of going off in tiny circles with unlocking etc, i would go for the quick fix and suggest your scanner may not have installed properly when you installed it. As you have installed the drivers again with no luck i would even suggest goint to samsung web site and downloading new updated drivers for your printer to eliminate corrupt drivers. Does you pc register the scanner being there? Go to control panel, hardware/ printers, find your printer and check all the drivers and whether scanner is actually present on the pc here.
Posted on Aug 30, 2007
  • Geraldine Watts Aug 30, 2007
    It definitely sounds like the scanner did not install, as it should show up in your pc. Good luck with new drivers. Please post back if i can further assist. cheers. lilacgerry
6ya staff
SOURCE:
My driver for samsung scx4521f is installed and prints but the scanner does not work
hello friend
in samsung driver cd their have a software SMARTRU that is the driver for scaning function so you have to install this driver.if u didnt found it
go the www.samsungusa.com and download it.
Jan 27, 2012 | Samsung SCX 4521F All-In-One Laser Printer
Samsung printer scx-4521f need smarthru4 scanner software
need a reliable site to download smarthru4 scanner software for Samsung printer scx-4521f
Oct 10, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F Scanner locked. I want to unlock it
is a switch under the scanner, change position
Mar 09, 2011 | Office Equipment & Supplies
Need samsung scx-4521f scanner driver
Here are the drivers:
Printer: http://downloadcenter.samsung.com/content/DR/200912/20091217112644875/SCX-4x21.zip
Scanner: http://downloadcenter.samsung.com/content/DR/200912/20091217112644875/Samsung_SCX-4x21_Scanner.zip
I hope you got the answer. :)
Feb 04, 2011 | Samsung SCX 4521F All-In-One Laser Printer
SCX 4521F scanner driver will not configure. Have tried repeatedly to download driver, download looks ok, but scanner never appears. SCX 4521F works fine as a printer/copier.
The problem is the firewall of your computer because its blocking the scanner to work better. Check the firewall of your computer from it is control panel if its on. If it is on, click the exception tab then check the network scanner tool and scan to pc box. Just put acheck on all scan or scanner word.
Jul 16, 2009 | Samsung SCX 4521F All-In-One Laser Printer
The OEMCFG.dll on Samsung needed
GO TO SAMSUNG/SUPPORT.COM
TYPE IN YOUR MODEL# AND DOWNLOAD THE DRIVERS YOU NEED.
Jul 15, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Problem scanning with samsung scx 4521f
Sorry to have missed your initial posting...
In any case, to my understanding, this particular printer is likewise capable of USB connection. Perhaps you can try connecting it pure USB and go through the installation again. this might simplify interface and communications between notebook and scanner/printer.
If for some reason you would want to retain Printer/Parallel to Notebook/USB, you need to check your Imaging Devices in the notebook's Device Manager and verify that all drivers are installed for the Samsung SCX-4521F. There should be no yellow or red marks. If there are or if the Samsung SCX-4521F instance is not present, you may need to reinstall using the Add Hardware Option in the Control Panel. You may need to manually select the imaging device/scanner. This holds true if you are using Windows XP.
If you are using Vista, you may need to download all the Vista drivers from the Samsung website. Further, pls be informed that to my knowledge, Vista has certain issues with USB ports. Microsoft has issued a patch/update specifically for this concern. It may be downloaded from here or here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Cannot operate scanner
Just posted two solutions to my problems. see here.
http://www.fixya.com/support/t134648-scanner_not_working
Hope it helps
Nov 02, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
730 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
