Question about RCA 27F500TDV 27 in. TV/VCR/DVD Combo
DVD PLAYS GREAT, TV AND VCR PLAY IN BLK-WHT W/NO SOUND
Dvd gives a great picture and good sound but tv/vcr show in blk-wht with a mostly yellow ,little red horz bands and a moving thin blue vertical band of color that shade over the blk-wht picture. also the DVD symbol can be seen faintly in the background.
  • randman27 Sep 07, 2007
    yes,i had this problem before and your solution worked fine, but this is an all in one box combo w/out a way to seperate or shut down the vcr or dvd indeviduly
    Sergeant:
  • 279 Answers
You have your DVD connected to your VCR, which is then connected to your TV, right? The problem is Macrovision. It's designed to prevent you from connecting your DVD player to your VCR, so that you can't make duplicates of copyrighted movies. It's a real pain in the neck. Try turning the DVD player off - or better yet, unplugging its power cord (as some DVD players are always in a standby mode, even when turned off). If that fixes the problem, then you need to reconnect your DVD player directly to the TV, not wired through the VCR. If your DVD player isn't wired through the VCR, are you using some kind of wire splitter (one cable branches into two) to connect both the DVD player and VCR? That can also cause this kind of interference, if both have power at the same time. There are video switches you can get to work around that. Here's one such switch (first I found for a decent price with a google search): http://www.pickeasy.com/20070827-video-selector-switch-video-game-p-555.html Hope that helps.
Posted on Aug 30, 2007
Magnavox dvd recorder/vcr
It sounds like you may have your vcr connected via composite cable. Check the back of your VCR and follow the cable to your TV. You should see a Red, White and Yellow connection on both ends. The Yellow connector is the video.
Here is an image to help you find it:
Feb 18, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When tv is turned on with cable channels picture is snowy. when dvd or vhs tape played through tv the picture is snowy
Try using the video inputs
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 13, 2009 | Televison & Video
No signal, no channels coming up. other TV's on same ariel working ok??????
Nov 04, 2009 | Goodmans Televison & Video
Blue screen. No audio or video through the cable hook up. RCA model #32V420T
Oct 25, 2009 | RCA 27F534T TV
We moved tv from living room to bedroom and the screen says "unusable signal"
Oct 05, 2009 | GE 31GT720 31" TV
DV1130 hooked up to TV, DVD works great. VHS has
If you are using RCA cables (Red Yellow White) the video (yellow) could be bad or not in the connector all the way. When the VCR mode is selected try pulling the yellow connector out then back in and see if anything changes on the tv.
If you are using another type cable let me know and I will help you diagnose.
Hope this helps
TankMurdock
Apr 25, 2009 | GoVideo DV1130 DVD Player/VCR
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
'SHARP LC 26SH12U' & Philps DVP 5160
sounds like you are using standard audio/video cables (yellow, blk., wht) in the component conections on either the tv, vcr or dvd player. If you intend on using component connection you will need to use different cables.
May 04, 2008 | Televison & Video
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
RCA 27F500TDV 27 in. TV/VCR/DVD Combo Logo
95 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
