Question about Standard (CRT) Televisions
I have a Wharfedale WH-TV21PFJ Pure Flat TV. On the screen FAC is diplayed in red which I can not remove. This does not allow me to increase volume, change channels etc. I can only make changes if I change the FAC to FACTORY by pressing the screen disply on the remote control. Pls let me know how to remove the FAC.
4 Suggested Answers
SOURCE: I need to remove child lock (without remote)
hi did you get to solve your problem becuase i have the same problem
Posted on Jun 11, 2009
  • 22 Answers
SOURCE: Wharfedale TV/DVD combo
Contact agent for the unlock code.
Menu and 4 digit code unlocks factory default.
Problem is caused when wrong sequence of keys on remote is pressed, part of parental control.
Posted on May 12, 2008
  • 23 Answers
SOURCE: Sansui Model no SAN 5452, text on screen
i think , there shoud be an option as (factory mode ---- on/off) in system , if true then modify it first.
if not true check all features in the menu for several times . other wise finally notedown the tv model number and buy a service modes for colour telivision , i think this boook is published by bpb. and search in that book for that tv model . adjust the service codes as there ...
if not available that book please mail me.
Posted on Oct 26, 2008
universal remote...that's the ONLY other option. SERIOUS... I've tried everything... lol
Posted on Feb 21, 2016
0 characters
1 Points
How can i cancel childlock on my wharfedale tv model WH-TV21NJ with a universal remote
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Unlock procedure and to override the password lock to many popular brand TVs are given.
May 04, 2015 | Standard (CRT) Televisions
Factory on screen at startup then goesto Fac and remains there
open ur backcover go to the front bottom ur remote controls panel take it apart clean it.
take ur remote control apart too change batteries,a good cleaning
Aug 15, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Apr 23, 2009 | RCA Standard (CRT) Televisions
Unlock Tv
Please view this FixYa Tip which outlines the procedure for removing the parental lock when the screen is locked on the Apex TV.
Thanks for using FixYa
Feb 21, 2009 | Apex Digital GT3215 32" TV
How to unlock my jensen tv
the tv should have buttons to change the input also. Or just hit channel up on the tv, that should do the same. That should do the trick if it is on the wrong input/channel. You could also try unplugging the tv for a minute. My tv goes back to channel 3 when unplugged.
Dec 01, 2008 | Standard (CRT) Televisions
Chuld unlock
to unlock the parental control on a Telefunken TV that has a blue screen and a red padlock on the top left hand side, hold down the display button on the remote for 10 seconds and it works
Sep 02, 2008 | Standard (CRT) Televisions
Tv, takes 30 minutes to open after switch on
resolder all cracked solders on the jungle you have any experience in electronics?
Aug 13, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Problems with 50 inch flat screen Panasonic
Yes there is a way to work with formatting your Tv. On your controller go to menu and settings and look for display. you can change where the words display. Bring them up or down. The lines, I'm not sure about. are all your connections nice and tight?
Jul 31, 2008 | Panasonic Standard (CRT) Televisions
we the same problem, our tv went blue with a blue pad lock in the upper left had corner.. we couldnt figure out how to get it off.. we even went to go and price tvs today... after looking for the tv manual and not being able to locate it, we decided to google jensen tvs and came up with this site... so thanks whom ever you are who said to hold down the display for 5 seconds and our tv was back!! thanks to whom ever u are with the last 2 suggestions!!!
Dec 10, 2007 | Jensen TS2750J TV
How to fix
Temporarily unsolder/remove vol up/down tactil switches on front of circuit board.They may be sending unwanted signals to the microprocessor. Does set work normally now? 2)Try removing batts from remote.3)PVAT! Pull chassis, Solder any/all bad connects esp. regulator pins.4)Send in to shop for diagnosis.
Oct 01, 2007 | Sansui DTV2760 27" TV
Standard (CRT) Televisions Logo
128 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
