Question about Epson WorkForce WF-3520 All-in-One Inkjet Printer
Epson wf 3520 repair manual
Paper jam
doc_delphi
  • 11 Answers
SOURCE: Epson AcuLaser CX11N ADF Paper Jam
I had a very similar problem with the ADF, it resulted in ADF paper jam - message and then in Req Code 2011.
I checked sensors and everything else, then called a epson service professional.
After telling him the Req Code, he knew the problem and said that the problem is the board, which needs to be exchanged, mentioning that this spare part is expensive.
I then checked the whole ADF again, now opening the long grey cover on the backside, I disonnected the connector cable from both sides and - using a multimeter - checked this connector cable for breaks.
Result: the violet cable was broken, so I soldered in a new wire, using the last cm of (old) wire on each side - and now the ADF works fine.
This cable is easy to change if you get the spare part, there is a connector plug on each side, on the ADF side is an additional ground wire (green) fixed with a single screw. Thats it !
For the electronic experts: the configuration of the connector:
sourrounding metal cover = ground, thick green Wire on the ADF side
If you turn the plug that way, that the two single contacts are on top, these are the colours:
1st row: brown - black
2nd row: green - yellow - orange - red
3rd row: grey - violet - blue
Hope this helps
Posted on Sep 17, 2008
Inky
  • 691 Answers
SOURCE: Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Posted on Nov 09, 2008
futureloginn
  • 734 Answers
SOURCE: Epson Aculaser C900 - Paper Jam Notice, but no Jam?
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Posted on Dec 04, 2008
57 varieties
  • 1653 Answers
SOURCE: EPSON R 300 SAYIN PAPER JAM WHEN NO PAPER JAMMED
Make sure that the paper path is completely clear and clean the paper sensors with a q tip. They get very dusty!
Posted on Aug 29, 2009
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
Epson WF-3529 printer seems to feed two sheets at a time when printing
In some countries, due to moisture in the air, during some weather conditions, this is common.
Fan paper well before loading in the tray.
Also depends on the type of paper.
Use manufacturer recommended grade. gsm80 in most cases.
Sep 06, 2016 | Epson WorkForce WF-3520 All-in-One Inkjet...
Why does ink cartridge not push down
Epson WorkForce WF 3520 All in One Printer
1. Are you sure you have the correct model ink cartridge?
2. Did you remove the yellow strip as shown in the illustration at the link above?
May 02, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
Paper Jam Error but there is no paper jammed. False error message
I know it sounds silly but when my Brother All in one does this the trick is to pull the main supply cord, count 10 and reconnect(Or turn off at the wall) The brain then reboots and all is well.
Feb 23, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
Wf-3520 scanner is not working
First check its power is on then check its data cable connectivty with pc.
Sep 27, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
What is error OxF1
0xF1 means there is a paper jam. Are any of the lights on the machine flashing? Are any of them solid ? Epson WorkForce WF 3520 All in One Printer
Sep 15, 2014 | Epson WorkForce 600 All-In-One InkJet...
Epson WorkForce WF-3520 All-in-One Inkjet Printer Logo
578 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
