Question about JVC SR-DVM70 DVD Recorder
Hdd no loading
Hello I have a JVC SR DVM70, it is the problem when he lights the equipment he remains indicating loading and it does not permit working for the otrs functions, they can help to me, Venezuela thanks
  • 4 more comments
  • wb9ofg Nov 15, 2007
    Same problem. This one had a tape jammed in it. I managed to get it to cough up the tape, but now it sits there dimly flashing "LOADING" on the display and no other functions are active. I hear some noises from the HDD that reminds me of a PC I had that went stupid and wouldn't boot.
  • Anonymous Mar 20, 2008
    I've had three of these units do the same thing, one came from the factory that way. JVC has sent me a new one every time.
  • videosteve Apr 19, 2008
    JVC wont boot up from hardrive justs makes buzzing noise
  • Anonymous Jul 05, 2008
    When I connect the recorder all I see is a flashing loading. I can't use any function.
  • dinesh_ku281 Aug 11, 2008
    I connected my recorders hdd to harddisk to copy the videos fast but Windows did not recognize the hdd partition. I connected back to recorder after which I started receving the LOADING message.
  • rocoghi98 Jan 22, 2009
    Ocurre lo mismo con mi unidad SR-DVM70. Cuando la compré se demoró 2 días "loading" pero al tercer dia estuvo bien. Ahora volvio a ocurrir lo mismo, pero ya va casi un mes y continua "Loading".
    La compré en USA, pero la tengo en Colombia. Escribí a JVC y me dijeron que no pueden hacer nada al respecto. Me ofrecieron el manual de servicio en FTP a través de Internet por "por solo US$30".
I don't tremember what the fix for this is, but I had it happen to mine. Luckily I had a budget to just take the machine in and have it fixed. It took them one day to fix it and it only cost me $70. if you can afford to just take it in, it would be worth it.
Posted on Oct 30, 2008
JVC SR-DVM70 intermittent no disk problems, all ready replaced power supply caps.
I would recommend to send it in for service at JVC service center in Long Beach, call 1-800-582-5825 for more information
Jul 03, 2014 | Video Cameras
What are the disc will support on this unit ?
From JVC's website -
Supported disc types:
Best regards,
Feb 10, 2011 | JVC SR-DVM70 DVD Recorder
I have a jvc SR-DVM70 - The hard drive is about 75% full of data so I don't want to lose that. The deck was working fine recording through the firewire to the hd. Problem was it didn't playback through the...
The hard disk hasn't been recognized in Windows because the JVC runs Linux so the drive was formatted in EXT3 which Windows can't read.
Simple fix to recover all your data: connect the disk back to the pc and boot from a Linux Live-CD like
In there all you have to do is to copy all the content of the disk to your local disk (PCLinuxOS can read and write securely on NTFS/Windows disks). Or you could just burn them to some dvd's.
For the rest: 1 - on the CS pins; 2 - no.
Jun 25, 2010 | JVC SR-DVM70 DVD Recorder
Hello, when dubbing from DV mini tape to HDD
well one solution may be the speed you are recording at. L.P. recording on a dvd often creates this problem. but usually it is when you copy dvd to dvd, not mini dvd to dvd
Never record more than 2 hrs on a disk
there are programs for a work around that reprocess the dvd vob file with adjustments for the sync.
could also be a hardware problem
is your mini dv long play source as well?
May 18, 2010 | JVC SR-DVM700 DVD Recorder/HDD Recorder
Want to finalize a dvd
If you use a DVD+RW you don't need to otherwise with a DVD+/-R you need to goto make compatible in the main menu
Apr 19, 2010 | JVC SR-DVM70 DVD Recorder
When i push ejected on my dvd player it comes up saying locked. How do i unlock it?
To unlock tray
While the unit is turned off, press and hold the stop button, then press eject the button on the unit. "UNLOCK" appears on the front display panel.
Apr 05, 2010 | JVC SR-DVM70 DVD Recorder
JVC Help
outputs display blurry image when using hdd and dvd setting. outputs give great picture when using dv setting. please help.
Aug 05, 2008 | JVC SR-DVM700 DVD Recorder/HDD Recorder
Driver in windows XP
Use this guide:
It's for a different model, but it works the same.
In a nutshell, when the "AV/C Tuner" driver request comes up, just cancel the install. Then, it will want an "AV/C Tape Recorder/Player" driver. It "should" install automatically and be instantly recognized. If not, follow the instructions in the guide.
There are also instructions in there for disabling the "Av/C Tuner" every time the deck gets connected. Hope this helps - worked for me! -
Feb 20, 2008 | JVC SR-DVM600
Dubbing to DVD not working
make sure the DVD is formated.
Feb 01, 2008 | JVC SR-DVM70 DVD Recorder
JVC SR-DVM70 DVD Recorder Logo
363 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
