Question about Microwave Ovens
My Hamilton beach microwave won't start. All the buttons work, but won't start cooking.
  • 140 Answers
SOURCE: Ge microwave model JVM1190WY buttons work but does not cook
The problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
Posted on Feb 11, 2009
domotek
  • 591 Answers
SOURCE: I have a Hamilton Beach
maby it's the magnetron, i need more information, a good way to test the magnetron is to put a small HE-NE lamp in a glass filled with water (HE-NE lamps) are found in any radioshack (La source) store, if the lamp glowes orange it meens the magnetron is good, if it is not glowing then the magnetron is dead, (the magnetron is allmost the price of the oven) it could be a fuse but if you have to change the fuse replace it with the same type (normaly ceramic german type) NOT GLASS
Posted on Jan 04, 2011
  • 3 Answers
Assuming its the same as my Hamilton Beach, you first enter the cooking time, but don't press start yet, instead press power, then a number button 1 - 9 for the power level 1 for 10%, 2 for 20% etc. THEN press start as normal
Posted on Jan 08, 2011
  • 205 Answers
SOURCE: I just received the Hamilton
Yes you do. If you look at the bottom of the unit you should find the model number. Goto the link below and download the manual for your unit. Should be listed under the Indoor grills option.
Owners Manual
Hope this helps!
Zzeppelinx12
Posted on Feb 23, 2011
Testimonial: "Thanks!! Very helpful to have the manual!"
  • 8909 Answers
SOURCE: We have a Hamilton Beach
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Mar 12, 2011
How do I set up the power level on a Hamilton Beach microwave model number is p100n30als3b
I believe all you need to do is first press the 'Power Level' button, then select a number on the keypad between 1 and 100 (where 100 is full power, 50 is half power, etc), then Press 'Time Cook' and enter the number of minutes and seconds as usual. I'd suggest testing on a cup of water so you don't risk overheating anything. And never run a microwave completely empty.
Good luck.
Mar 21, 2015 | Hamilton Beach Microwave Ovens
How do I change the power level
I have a Kenmore, but you can try this: when you're about to cook, put the time in, then press the power button. Put the power level in, then press start.
Oct 26, 2014 | Hamilton Beach P100N30ALS3B Black...
How do we start the microwave
sounds like faulty door switch ie micro switches about 4 of them
May 20, 2014 | Hamilton Beach Microwave Ovens
Microwave won't start
The door interlock may have failed.
Mar 24, 2014 | Hamilton Beach HB-P100N30AL-S3 - 1.1 CF...
Microwave turntable won't turn.
Return the item to the place of purchase this is a manufacture defect. The problem is caused by a defective turntable motor.
May 20, 2012 | Hamilton Beach Microwave Ovens
I have a Hamilton Beach 0.9 Cubic Feet 900-Watts Digital Microwave Oven and I can not find out how to change the power setting for cooking.
Oct 29, 2010 | Microwave Ovens
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
