Question about Lasko High Velocity Space-Saving Blower Fan HVB - 4924
Lasko 4820 does not oscillate
Makes a beeping noise when power is turned on, but does nothing else
2 Suggested Answers
SOURCE: I have lasko fan sudenly it stoped oscillating can
I have the same issue, i determined the oscillating motor has a bearing failure. I need to find a replacement motor.
Posted on Jan 10, 2010
Osilating stopped on lasko 2554 fan
Lasko's are good for stripping the gear in the base that makes it oscillate. If it's still under warranty, they will send you a new fan.
Jul 28, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
My lasko tower fan works bot stopped ossilating
Well could be several things that could make it not oscillate. Motor is bad, stripped out teeth or gear slipping on motor. You would have to take it apart and see if you are even getting power to the motor.
May 28, 2015 | Lasko Dryers
My Lasko 5307 oscillating ceramic tower simply does not "turn on" .... what's up?
Electricity is not suitable for use by you....
Check power point with another appliance. Check heater switch, high temp, etc....
Oct 16, 2013 | Lasko 5307 Oscillating Ceramic Tower...
When I turn my HP Pavillion on, it makes 1 long 15 second beep then about 5-10 seconds of silence then another 15 second long beep. It does this continuously. There is nothing coming up on screen at...
If not solved yet, make sure the fan is spinning on the heat sink on the processor. If it is, then if you have a video card installed, make sure that fan is spinning. These are 2 pieces of hardware that will cause the beeping and shut down.
Dec 13, 2010 | HP PAVILION A6230N DESKTOP PC
My skytronic power invertor is making a constant beeping noise
do you have a load plug in at the time if so try it with nothing plugged in if all is fine the load may be to big for the invertor
Apr 04, 2010 | Electronics - Others
I turned on my aspire x3200 the fans make a loud noise but nothing appears on the monitor at all and there is no beeps!
No beeps mean ram fault.
NB = Ensure power is disconnected from PC
Pull cover off and remove / replace ram / retry.
If still no go try removing ram sticks so that there is just one there. If only one any way borrow a stick from anywhere and try.
Ensure all fans are working also.
Dec 22, 2009 | Acer Computers & Internet
E6500 making a beeping noise
Does beeping noise happened before turning on laptop? If yes unplug the laptop from the AC Adapter. Just leave AC Adapter ON and connected to the power outlet. Check if AC Adapter is the one making beeping noise. Note: This is an issue with dell AC Adapter laptops
If no beeping noise in AC Adapter then proceed checking it from the laptop. Does beeping noise happened immediately when laptop is turned on? If yes then it might be laptop's hard drive creating the sound. Try to check the BIOS in your laptop under the category performance if the HDD Acoustic is ON either in Normal or Performance. Note: When laptop is in performance the hard drive makes noise due to its speed, this is normal if BIOS HDD Acoustic mode is ON to performance.
If the noise only happens when sometime while working on the laptop, this might be cause by the laptop fan. This also happens after turning on the laptop fan my have dirt and dust, please do check.
If fan was cleaned, HDD performance was checked and AC adapter was checked then, carefully sense if noise is coming from the internal speakers.
Download the latest BIOS update for your laptop then flash the BIOS. Make sure battery and AC adapter are connected when doing these.
Dec 11, 2009 | Dell Latitude E6500 Laptop
Lasko High Velocity Space-Saving Blower Fan HVB - 4924 Logo
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
