Question about HP PSC 2175 All-In-One InkJet Printer
HP Printer not pulling paper
My printet can not pull paper when I try and print any information.
    Sergeant:
  • 390 Answers
Check for a jam in paper feeder, look down back with a torch, open up unit and search inside, have a pair of tweezers handy as jams can occasionally be very minute and hard to grab.
Posted on Aug 30, 2007
SOURCE:
Hpc6280 paper caught internally
This information comes from the User Manual on pages 111-112:
http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf
Internal paper jams on this machine tend to be in the two-sided printing accessory.
To clear a paper jam from the two-sided printing accessory:
1. Turn off the printer
2. Press in the tabs on the left and right side of the two-sided printing accessory, and remove it by pulling out from the center of the printer.
3. Gently pull the paper out of the rollers. If the paper has torn, check the rollers and wheels for small, torn pieces of paper
4. If it's still not clear, open the two-sided printing accessory by pulling up on the tabs, and remove any paper stuck inside it, then close the accessory by pressing down on the tabs until they lock into place
5. Replace the two-sided printing accessory by pushing it forward until it snaps back into place
6. Turn on the printer, and verify that it works by pushing OK to continue the job it jammed on.
Feb 27, 2014 | HP Office Equipment & Supplies
HP 2600 does not print onto photo paper
change the paper type in the printer properties and try.
Jan 09, 2010 | HP Color LaserJet 2600n Printer
No words print when the printer pulls the paper through
HP support has information that may help: (copy and paste this link into your browser)
http://h10061.www1.hp.com/ccsearch/search?pname=PSC+1510xi&qry=prints+blank+page&submit.x=11&submit.y=5&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=&productBigSeriesOid=&spid=&opname=&pname_desc=&ptype=&stype=fs&contextual_lname=&spname=&temp_hql=&product_line_code=&search=0
Choose the solution that best fits your problem.
Dec 05, 2009 | HP PSC 1510 All-In-One InkJet Printer
Printer starts to pull the paper to left side & jams
You may need to clean the printer. See help here, , and diagnostics here. For other concerns, please consult the product support home page for your model here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 23, 2009 | HP Photosmart C5180 All-In-One InkJet...
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
The printer is not pulling the paper into the printing mechanism
My printer is blinking and not pulling paper. That apart there is word showing mechanical error and cartridge craddle cannot move etc. etc. but sometimes it is found OK.
Manabendra
[email protected]
Feb 09, 2009 | HP DeskJet 3550 InkJet Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
The rollers are not pulling paper through
- the roller not pulling paper through
- orange and yellow lights are flashing
Nov 02, 2008 | HP DeskJet 960c InkJet Printer
Paper Jam
With printer unplugged, open lid and pull paper out by hand. Depending on where paper is jammed, you may have to lift out toner cartridge first. Be careful when pulling out paper, especially if paper is crumpled up. Sometimes it is easier to pull paper from back of printer as if it were continuing to print, and others it is easier to pull reverse from the front.
May 17, 2008 | HP LaserJet 4L Printer
HP PSC 2175 All-In-One InkJet Printer Logo
52 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
