Question about Brookstone OSIM uDivine App Massage Chair
Udivine app chair. When I plug in my chair ERROR 2 appears. The remote does not respond.
How to fix the ERROR 02 on a OSIM UDivine S massage chair?
Error 2 is updown motor sensor is not working. Replace sensor. Will ok.
Jun 07, 2016 | Furniture
Won't upload import photo parameter error appears
do you have Windows Phone app loaded?
some usb 3.0 does not respond well on Nokia phones, try to use a usb 2.0
Dec 26, 2013 | Computers & Internet
I need a remote control for my HTT-9 Human Touch Massage chair.
My htt-9c would beep and not work. E-mailed company and they said chair was out of production for a while and they would give me a discount on a new one(no replacement parts). I peeled the sticker off of the top of the remote and had to remove 4 tiny screws. Inside the remote there was 2 more tiny screws to remove. Went to radio shack and got a 25' phone cord for 11 dollars and plugged it in the remote and back of chair. Fixed the problem
Oct 23, 2011 | Interactive Health Refurbished Htt 10crp /...
Battery indicator seems fine. Wrench symbol is lit. Chair won't respond to joystick control. Any suggestions? It worked when I put it away a few months ago and now, nothing.
The wrench symbol being lit indicates a problem. Does the wrench symbol blink? when you try to engage the joystick the brakes should try to engage and you would hear them click and the symbol will flash. The number of flashes telling you what is wrong. If the symbol is not flashing and staying on then that also a probem but you can't tell what it is. Either way the chair will have to be checked by a tech that has a programmer to plug into the chair and read the error codes to determine the problem. Check with your provider that sold you the chair to see if they can troubleshoot the chair for you or contact Invacare Tech Support @ 1-800-333-6900 and explain your problem. Sorry I can't give you a definite answer Hope this helps
Mar 07, 2011 | Invacare Supply Group Invacare Pronto M91...
The Responder LC remote for my Viper 5901 will not charge. What can do I do to fix this? I have only had this system for less than 2 months.
Plug the charger into an outlet. Plug the charger into the remote, unplug the charger from the remote. Repeat until "charge" appears on screen of the remote. You may have to repeat the process approximately five times until charge appears. There was an issue with the batteries in the remotes having to be reset. If this does "fix" the issue, your problem may be with the charger itself. You can use any usb charger to charge the remote, i.e. phone car charger, computer, etc.
Feb 02, 2011 | Viper 5901 Security Remote Start System
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Wont turn on light just flash back and forth on speed setting
gilly your controller still thinks you are charging the chair. This error is a charger inhibit error which means that when you have the charger plugged in you can't drive the chair. If your charger is not plugged into the chair then you have a problem that needs to looked at by your provider where you got the chair or by a tech Sorry I don't have a quick fix Hope this helps you
Sep 25, 2010 | Pride Mobility Products New Pride Mobility...
Chair has been idle for years. I tried to turn it on and nothing happened. I plugged it in and waited 2 hours, all the lights came on. Looked at the owner's manual and it was pretty useless to me. So, all...
Robbin,
It will not help to try to charge those batteries. No amount of charging will bring them back You will need to buy 2 U1 batteries if your chair is a smaller Jazzy or Jet. The heavy duty chairs take a bigger size battery Hope this helps you Check if there is a battery distributor or store in your area they will be cheaper than going to a provider that sells chairs
Sep 05, 2010 | Jet Health & Beauty
Help my son has just snapped the white cable off his pyramax s1000 chair
I also purchased the chair and the white cannon plug goes to the white plug on the back of the audio on your t.v. as does the red to the red. The green plug on the otherside of the Y cable goes to the remote device and bo the chair and remote need to be set to the same channel.
Jan 04, 2009 | Pyramat Sound Rocker Gaming Chair
Not getting any power to chair
Make sure there is power at the outlet. Check the fuse panel. If there is still no power then check to make sure there is no GFI (ground fault interupt) switch on the chair itself. The GFI is a 2 button switch that will say "Reset" and "Test"
Nov 30, 2008 | Interactive Health Black Leather Ht 130...
Brookstone OSIM uDivine App Massage Chair Logo
136 people viewed this question
Top Brookstone Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Brookstone Furniture Expert? Answer questions, earn points and help others
