Question about Pentair Pool & Spa
Flotec sk2 schematic
Cannot get the pump to come on. Is the L1 and L2 from the breaker or the controller (capicator box)?
john224
  • 1378 Answers
SOURCE: I am installing a Hayward Pool pump max flo II at
Either one. Neutral to the other post. Be sure to set the voltage change device to 115V to match your incoming line voltage.
Posted on Sep 15, 2009
Testimonial: "That's outstanding info for anyone installing a pool pump. Tom Smith"
StepehnD
  • 78 Answers
SOURCE: If you are replacing a 2 hp pump with a Hayward 2
Shouldn't be a white line on a 220 circuit but some people use them. Red and Black is the standard. If you are sure they supply 220 VAC, which I would verify, it doesn't matter which one goes to which terminal. 120 or 3 phase matters. If you have a multi meter, put the red lead on the black wire and the black lead on the white wire. If you read 220, good. If you read 120, it will make a difference.
Posted on Jun 26, 2010
adamh294
  • 310 Answers
SOURCE: Wiring up Emerson 1081 pool pump. Is L1 terminal
For your 240 volt operation L1 and L2 will both be Hot 120volt lines.
Ground to green ground screw and bonding wire to bonding lug (if needed)
Please vote positively for this post if i have helped you.
thanks
adam
Posted on Nov 02, 2010
jturcotte
  • 8273 Answers
SOURCE: wiring a 230v ao smith
Hi, assuming you have 4-conductor wire, use the black and red wires for L1 and L2. It doesn't matter which goes to which. If you do not have a red wire, use black and white. The green or bare wire in a 3-wire cable goes to the ground. If you have 4-conductor wire, the ground wire is the one you used for the GFCI on the breaker--usually the white wire. Please let me know if you have more questions, and thanks for using FixYa.
Posted on Aug 08, 2011
Vanguardian
  • 106 Answers
SOURCE: I JUST GOT A MARATHON 220V. POOL PUMP MOTOR TO REPLACE THE 1 HP.STA-RITE IT WAS WIRED FOR 220V AFTER HOOKING THE L1,L2 AND NUETRAL ,NOTHING IS HAPPENING I TESTED THE WIRES ,MADE SURE BREAKERS /CLOCK ,
Use the caps lock key OR YOU WON'T BE HELPED!
Posted on Jun 05, 2012
Can you get me a diagram on electrical hookup?
Hello;
My name is Peter. I am a retired field service technician.
I do not know if you have a 3 wire or 4 wire connection. For a 3 wire connection you need 15 AMPS at the breaker box. For a 4 wire connection you need 30 AMPS at the breaker box.
Three wire hookup. Center wire goes to N, the other two wires are hot. It makes not difference witch of these two wires go to L1 or L2. The ground goes to the cabinet.
Check the voltage - With a volt meter between L1 & N = 220V, L2 & N = 220V, L1 & L2 = 240. These readings are general. You may get something like 210V instead of 200V
Mar 10, 2015 | Dryers
WIRING A COMPATIBLE POOL PUMP[MARATHON 1 H.P.230V
check for 230v not 110 (on line to ground). SO checking L1 and L2 should show 230 v if not you have a fault in the timer or the breaker is toast. depending on the timer you can clean the points
Jun 30, 2017 | Pool & Spa
How do you wire the intermatic fd60mwc timer 220v? there are no lugs for the second line and load on the right side of the unit.
You can turn off 240Volt circuit by turning off 'one leg.'
240Volt circuit has two hot wires that come from breaker box, so 240V has two legs:
These hot wires are usually labeled L1 L2 in wiring schematics.
FD60 timer is usually SPST and has two wiring terminals, but some versions are SPDT and have 4 wiring terminals.
Cut L1 line in half, and put each end into FD60 terminal.
Open following link for rough drawing:
http://waterheatertimer.org/images/FD60-wired-to-control-240V.jpg
Open following links for more illustrations and information:
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Jul 27, 2011 | Intermatic FD60MWC Energy Controls -...
I need to hookup up a Grasslin GM40 timer controlling one load and a 120vac application. Just wondering if someone could verify the hookup terminals as I cannot read the schematic as it is mostly gone. ...
Open following links to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#GM
GM40 can be used for 120V or 240V 277V applications for single-phase and some 3-phase applications.
For 120Volt, set all 4 dip switches to ON position BEFORE applying power.
ON position is pushed to left.
120Volt cable from breaker box has black hot and white neutral wire.
Black hot typically connects to terminal L1
White neutral connects to terminal L2/N
This action will power the time clock and relays.
Other terminals on GM40 are the relay terminals, and these terminals are dry.
Dry means they receive no power when wires are connected to L1 and L2/N.
There are two independent relays and each relay has 3 terminals: NC NO and COM.
If you are controlling one 120volt Load, then use one relay.
Run a jumper wire from terminal L1 to COM terminal.
So COM terminal is connected to Hot.
Cable going to 120V Load has black and white wire.
Connect black Load wire to terminal NO (normally open).
Connect white Load wire to L2/N.
Jul 19, 2011 | Intermatic GM40 - 24 Hour/7-Day Dial...
I have a Kenmore 90 series electric dryer that will not heat. Model is 110.62922100. I have the schematic and have checked all the thermostats, thermal cutoffs,timer contacts,the motor rotational switch,...
Check your breaker box. If one side trips it will run but will not heat. Common problem. Try checking L1 to N, and L2 to N, you should have 110 and 110 if you dont than it,s your breaker. I would just check your breakers. Make sure you give me a thumbs up if I am right.
Aug 21, 2010 | Kenmore Dryers
On the fp3222-11 well pump it said it needs 230v, is that on both hot leads, that each lead has to have 230v reading?
That means when you check your supply voltage it will be 230V from hot to hot.(L1-to L2) You would still read 115V to neutral on each leg.
Aug 17, 2010 | Flotec 075 HP Submersible Well Pump 3Wire...
A/c outside unit is not working- fan will not work.
I assuming that the black box is a 100 amp breaker, which is connected to your condsensing unit (outside unit). If you open the box and pull the fuse then this will turn off/kill the power to your unit. As far as the buzzing noise it could be that the contactor is engaged. Hopefully, your fan motor is burnt out or the capicator is bad. If you take the access cover off and check for voltage at the contactor you should know if it is the fan motor. The voltage will come in at the bottom T1 T2 T3, once the contactor is engaged L1 L2 L3 will have the same power. Of course if your contactor is not engaging then thats the probelm, you can manual engage the contactor by pushing it in. There will be four wires two running to the capicator and the other to the contactor, these are the wires that control the fan motor. The other three wires run to your compressor. Hope this Helps Tim
Aug 03, 2010 | Heating & Cooling
How to install 25amp 3 pole relay
There should be 8 screws on the relay L1, L2, L3, T1, T2, T3 and two additional screws either at the top or bottom, or one on each side. The incomming, constant power in from the circuit breaker, should connect to L1, L2 & L3. The power out to the load should connect to T1, T2 & T3. The control wire from the switch or timer you will be using to close the contactor will connect to the remaining two screws. THE MOST IMPORTANT PART IS THAT THE CONTROL VOLTAGE MATCHES THE COIL VOLTAGE OF THE CONTACTOR. They will make 12vac, 12vdc, 24vac, 24vdc, 120v, 240v, 277v, etc. coils for the contactor.
Also keep in mind that when the contactor closes L1 & T1 make contact, L2 & T2, Etc.
Oct 08, 2009 | Eaton ARC FAULT CIRC BREAKER
Problems wiring Flotec sprinkler pump
L1- L2 doesn't care if blk or red. Make sure there is 220vac (240vac) on the supply wires. If there is there is something amiss with the pump. Eric
Jun 21, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Pool & Spa Logo
22 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
