Question about Water Filters & Coolers
Addico water cooler freezing
There appears to be a leak in my model 915cx addico water cooler
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
Oil in coolant . oil cooler bad but which one
Oil generally will get into the coolant due to a headgasket leaking, or a cracked head.
You'll need to pressurize both systems (OIl & Cooling) to try & determine where the leak is coming from. .
Antifreeze in the oil can cause the pistons to sieze in the cylinders and if you've got oil in the anti-freeze, you more than likely have anti-freeze in the oil, or soon will.
Good luck.
Feb 18, 2010 | 1999 Saab 9-5
My refrigerator leaks water on one side & the water collects in one of the vegetable coolers. I am now unable to use that vegetable cooler & am having to constantly wipe up. The seals appear to be...
I have Model ET8CHMXKQO-3 whirlpool fridge with the same problem. The problem I believe is due to the drain line to the tray that collects defrost water freezing up. Temporary solution is defrosting the fridge; permanent solution is running a thin wire thru the drain line that aparently prevents the condensing water from freezing. I am trying to find out how to install this wire and where to buy it.
Jan 28, 2010 | Whirlpool Refrigerators
Cold water is freezing
if ur water cooler is freezing there could be two different things wrong, one yes is the thermostat, the second how ever is a relay switch located at the bottom of your cooler.
need any help? omilian.jos@gmail.com
May 04, 2009 | Hamilton Beach Water Cooler with Storage...
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a sunbeam water cooler and it leaks can u help me..
Hello dneary55
You said, You have a sunbeam water cooler and it leaks can u help me..
Where is it leaking from?
What is the model number and how old is the water cooler ?
If you are under warranty ( Which is 1 year parts and labor
Below you can find an authorized Sunbeam service center.
http://www.sunbeam.com/servicelocator.aspx?section=kitchen
If not you may want to use a sponsored service center here at fixya.
Waiting to hear back form you
Huuum
Sep 30, 2008 | Sunbeam Refrigerators
It is freezing up inside the cooler
Turn the screw on the back of the unit so that the water is not chilled to such an extreme cold
Jun 20, 2008 | Avanti Hot and Cold Water Cooler
Water Filters & Coolers Logo
66 people viewed this question
Top Water Filters & Coolers Experts
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
