Question about Kitchen Ranges
I need to replace hood fan speed control P/N PE050033. MOD. SMC1270PT
That control the fan speed inside the Viking Hood.
SOURCE: cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Posted on Feb 18, 2008
SOURCE: Random fan speeds and light levels???
I do guarantee work for Broan & Nutone on the road. The problem with all three of your kitchen fans is the control board which is $110.00 part # R111632 for allure 3. If ever, im in Montreal,qc 1-800-363-0566 = Inventex
Jean-marc
Posted on May 14, 2008
shaggyrat
  • 1224 Answers
SOURCE: Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Posted on Jun 01, 2008
  • 6 Answers
SOURCE: viking hood light went out . new bulbs . did not fix it
the dimmer switch/thermostat is most likely bad. resistor inside is burned.p/n pe050033  you can change it yourself with a little mechanical aptitude.
Posted on Feb 25, 2009
SOURCE: replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at robert_attieh@yahoo.ca
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
Posted on Aug 03, 2010
How to replace control switches for a venmar hood fan
[PDF]Download - Venmar
www.venmar.ca/DATA/.../131_5_en~v~Installation_Manual.pdf
Before servicing or cleaning unit, switch power off at ... solid-state speed controldevice. 8. ... should not be allowed to accumulate on fan, filters or in .... We recommend to install the hood at a minimum distance of 24" from an electric range and.
FAQ - Venmar
www.venmar.ca/en-faq.html
Can I use other controls than Venmar controls with my unit? What is the ... Range Hoods. Can I replace an "over-the-range" microwave with a range hood? ... VenmarConnaisseur C270 and C600M ยท Rocker switch control. Venmar V10 ...
Range Vent Hood Switch Parts In Stock from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Range-Vent-Hood-Switch-Parts
Shop for your Range Vent Hood Switch from our huge inventory. Check our ... RepairHelp for Range Vent Hoods ..... Blower variable speed control switch.
Range Vent Hood Repair Help - Free troubleshooting
Jan 23, 2016 | Venmar Kitchen Ranges
Hood not getting power. Authorized viking tech said I need to get an installer to remove the hood before he could see what the problem is. Is this typical of techs to not remove to troubleshoot?
It depends on the installation: larger hoods, intricate installs and liability concerns could all raise this concern by a tech. It should be simple to begin by checking for electric at the wiring connection inside the hood terminal box without removing the hood from the cabinet. If there is no power supplied to the hood then an electrician should correct the fault in the house wiring.
Dec 03, 2014 | Viking Kitchen Ranges
Viking Professional VWH4848 fan hood not working
Have you tested with a VOM to see if there is juice at the plug in question? If not, trace it back to the control/switch area and test there... Careful!
Mar 16, 2009 | Viking VCSF036SS 36" Professional Free...
Need New Fan knob for Viking VWH3048
You could contat any viking dealer and they would be able to help you, or you could go online to viking.com; finally you might find a replacement knob at a hardware store like a Valu where they usually have a large assortment to choose from.
Jan 31, 2009 | Viking VWH3048 Kitchen Hood
Viking hood light went out . new bulbs . did not fix it
Oct 21, 2008 | Viking VWH3048 Kitchen Hood
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Brand new Viking 3048SS hood - fan switch not working
think i would call viking back and ask for refund of inspection fee and go by the bad switch scenerio the electrician said new fan that would be considered flaws in workmanship in most states dont know where you are located but pretty much same anywhere most inspectors for these companies always try to blame problems off on installers hold your ground and make them fix it and refund that" inspection " fee I've been doing electrical work for several (20+) years it takes longer than 5 minutes to troubleshoot something like that good luck
Jun 01, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Viking hood Lights out
Part PE050033 no longer exists. It's now two parts: PE050141 for the light and PE050156 for the fan. You must first remove all of the small switches then pull off the front panel to tighten the small nuts that hold the new units in place.
Dec 09, 2007 | Viking VWH3048 Kitchen Hood
Kitchen Ranges Logo
301 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
