Question about Car Audio & Video
How to unfreeze a kicker solobaric subwoofer - Car Audio & Video
2 Suggested Answers
SOURCE: kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Posted on Feb 03, 2008
Would a 10ZX750.1 amp be alright on a Single Solobaric L5 10" inch in a ported box???
yes, the 10ZX750.1 is capable of running two L5's at two ohms in either a ported or sealed box. Just be sure to wire it up to suit your needs correctly (if you need to know how i can help) and make sure that your box dimensions match what kicker specify. the L5 is actually one of the subs that kicker reccommend for that amp.
Hope I helped , and please dont forget to rate.
cheers
Jan 15, 2011 | Kicker Car Audio & Video
Does the solobarics fit in a mitsubishi diamante in the sealed box it comes in 12 inch
i dont see why not you could probably do 2 in a ported box and make it sound 2 times as better then sealed
Apr 02, 2010 | Kicker Solo-Baric L5 Car Subwoofer
I wanna know if a 1500.1 amp good for 2 15'' kicker L7 solobarics
yes but you might get better results from it if you wire it for use on 2ohms
Oct 13, 2009 | Car Audio & Video
I have 3 Kicker solobarics Hooked to 1 ohm, But
It likely has a blown voicecoil - or the voicecoil is damaged in a certain spot - so when you play a certain frequency it cuts out.
Aso check the integrity of the tinsel wires - if they are loose or hitting the basket, it would stop playing.
BTW - it is impossible to wire a 1 ohm load with (3) single or 4ohm voicecoils.
Be sure your wiring is correct - or the amplifier will be the next thing to go.
Thanks for using FixYa - Rating this FREE answer is appreciated.
Jul 05, 2009 | Kicker Solo-Baric L7 10'' Car Speaker
Craking sound
its either a bad voice coil or your amp is under powered while hitting good bass, could try a CAP or replace your car battery
Mar 16, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
How to wire up my kicker 12inch solobaric l5 2ohm to my zx500 2ohm mono amp. should it be ran in parallel or series? what is the best suggestion
Well first of all all solobarics are dual voice coil so you have 2 2ohm voice coils so if you wire them in parallel the sub will be pulling a 1ohm load wich would in time blow out your amp. So you want to wire both voice coils in series to produce a 4ohm load.
Oct 25, 2008 | Kicker Car Audio & Video
Blown solobaric?
how did he messed up? anyways, if u push the cone of the sub down and u hear a sound like "TUN!" its most likely ur sub is irremediably damaged. The cone needs to come up perfectly as a good sub would do. I need to know exactly what ur friend did b.c it is quite weird to mess a good sub by slightly switching cables
May 24, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Installing my woofers
hi there james. What you can do is connect the cables as normal. 2 to the left, 2 to the right. Then at the cable's end you need to mix the red left cable with the right red cable, and so on with the blacks. and its done. Now instead of 4 cables you have two. If you need further explanation please ask
May 23, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Kicker solobaric l5 12''
Sep 25, 2007 | Car Audio & Video
Car Audio & Video Logo
149 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
