Question about Sewing Machines
How to do a baste stitch with my brother 3500 xl
  • 192 Answers
SOURCE: Husky 165 - won't do a basting stitch
Set the machine to its longest stitch length, put it in the warmest room in your house and in the sun if possible. If the stitch gets longer when the machine is warm it needs to be cleaned and lubed so that the stitch length mechanism moves freely.
If the lube in the machine is getting old or is nonexistent, the reverse button may be depressed and appear to return to its original position, when released, but the mechanism inside the machine only returns part of the way causing the length to be shorter than normal. Heat often masks this problem allowing the mechanism to move.
Posted on Nov 14, 2007
talk2ginny
  • 34 Answers
SOURCE: tension setting XL 3500 Brother
Hi, and welcome to FixYa. Normally, the default top tension setting on most machines is between 4 and 6. Brother manuals usually contain detailed information about tension and how to determine if your tension is set correctly, so check that section of your manual when you have time....if you don't have your manual...
you can find a copy to download for free on Brother's website (I added a link to the web page below). The same web page has other information about your machine that you might find helpful now or in the future. Even if you have the manual, it is worth a visit.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/model_top/HomeSewingMachine/hf_xl3500t3510eus.html?reg=us&c=ca&lang=en&prod=hf_xl3500t3510eus
If you and other readers have a minute to rate my answer, it helps me better understand what readers are looking for when they come to the FixYa site for help.
Best of luck, and enjoy your machine. Don't hesitate to comment if the link doesn't' work, or if you have more questions. Cheers!
Posted on Feb 04, 2009
SOURCE: Brother XL 3030 i can't seem to get it out of the
it is easy to switch the stich modes
there are two wheels on the side on the mchine
one in for manualy stiching *the big one)
and the little one changes the stitch
you have to look at the LCD screen to make sure the numbers correspond
Posted on Jul 21, 2009
  • 16 Answers
SOURCE: How do I adjust the bobbin settings on my Brother XL-3022
Well is your machine skipping stitches? "Not looping" does that mean not creating a stitch? To adjust your bottom stitch you usually adjust the top tension regulator. I can try to help you more in detail check out my forums http://www.sewingmachineryrepair.com/forums/index.php
Posted on Feb 28, 2010
  • 1116 Answers
SOURCE: Brother XL-2022 Bobbin Problem
Removable parts are the race and bobbin case.
Raise the needle to it's at the highest position and set the race hook into the shuttle so the hook is at the lower left.
Re-place the hook race cover and move the levers or pegs to hold the cover in place.
Posted on Apr 18, 2010
Does the brother inovis v-5 have a basting function
A basting stitch can be done on most any machine. Just extend the stitch length as long as possible and loosen the top tension so the bobbin thread lays flat on the underside of the fabric.
Jul 08, 2017 | Brother Sewing Machines
How do you machine baste on a brother PE 830DL I am wanting to embroider on stretch material and I was told to float the stretch material and baste it to the tear away in the hoop thanks
A basting stitch is just a matter of setting the stitch length to very long. If you want to remove the basting stitch after your project is complete, you can also loosen the top tension so the bobbin thread will pull out very easily.
Wondering if a wash-away fabric spray adhesive will work just as well.
Apr 07, 2017 | Brother Sewing Machines
Where do I find the switch to the Feed Dog on Brother XL-3500
ARE YOU TRYING TO WIND A BOBBIN? YOUR HAND WHEEL CAN BE PULLED OUTWARDS AND THE DOGS WON'T WORK. THE ADJUSTMENT ON THE TOP WILL CHANGE THE LENGTH OF THE STITCH SO THE LENGTH OF THE FEED DOGS IS CHANGED.
May 11, 2014 | Brother XL-3500
My brother ce8080prw machine will not stitch in reverse and is stuck in abasting stitch. how do I reset?
My machine was also not sewing in reverse and stuck in a basting stitch. It was a simple fix. Unscrew the plate and remove any pins stuck in there. All fixed
Nov 04, 2012 | Brother SE-270D Computerized Sewing...
How do I set for basting
Some compuerised machines will have a basting stitch programmed in, it may have a symbol like a dot then a long dash then another dot. This will give you a decent spaced basting stitch. On mechanical machines sometimes you can get a basting needle plate - you set up for the longest widest zigzag stitch and the tube on the plate makes one side of the zig not catch so you get a long straight stitch.
But if you are joining silky fine fabrics together, then needle and length of thread doubled is still the best way, takes a little longer but the fabrics won't creep and slip.
Oct 23, 2011 | Brother PS-1250 Pacesetter
I have no instructions for my old Brother Star 3 sewing machine & need to adjust the stitch tension.
Try http://www.brother-usa.com/modelDocuments/Consumer/users/%20Manual/UM_XL.2600i_ENES_1478.PDF Jimy
Jun 10, 2011 | Brother XL-3500
Sewing Machines Logo
47 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
