Question about Electrical Supplies
What kind of sparkplug do I need for a craftsman 10 Hp gentek ohv 5600 watt generator
2 Suggested Answers
  • 1267 Answers
SOURCE: My 4 year old Craftsman
Not that i am aware of, however, I suspect that as soon as you load it up it will die again as the load will call for greater speed, and too much fuel from the choke position will cause it to die again.
What I suspect is that your carburator is clogged up at the jets and is not metering the air fuel mxture properly. You may have to disassemble the carburator and clean it. Since the government has mandated that gasoline contain 10% alcohol, it has become a night mare for small engines that are not used very often. The alcohol is very hydroscopic (retains water) and during the off use period, the alcohol evaporates and leaves the water behind to mix with gunk and clog the needle valves.
Try removing the old gasoline. Refill the machine with fresh gasoline and add some "SeaFoam" (an additive) or any other brand additive that will help disolve the built up gunk in the carburator. Remove the air cleaner and try spraying a carburator cleaner down in the air intake while the machine is running, this way the air passages may clear while the new gasoline may dislodge the built up gunk. Note: The carb cleaner will stall the engine.
It is probably wise to run the gas tank dry before storage and only fill when the machine will be used. Stabil is an additive for storage, and it did it's job before the alcohol edict. I am not sure that Stabil will allow long time storage. (more than 3 months) SeaFoam can be purchased at WalMart, stabil is on the shelf of most small engine sales rooms such as Sears.
Posted on Jan 09, 2011
Where is the coil located on my craftsman 5600 Watts generator
Follow the spark plug wire back into the generator. It ends at the coil.
Jul 29, 2016 | Watts Electrical Supplies
Craftsman 5600 watt generator won't stay on and white smoke pours out when started.
try running it with nothing hooked up if it runs fine, then the power draw is to much for it that would cause it to hunt !!!
Jan 30, 2013 | Craftsman 5600 watt Generator
Gen power shut down every 10 to 15 min
try and run it with the gas cap loose the vent could be plugged up if it stays running but pops the circuit breaker the your over loading the system
Sep 03, 2012 | Craftsman 5600 watt Generator
Just up graded from a homelite 4400 to a craftsman 5600 generator 5600 does not have enough output as did the 4400 why
Some manufacturers tend to fudge the numbers and throw around the 'peak' output power as continuous and it isn't. Peak (or surge) is the power a generator will handle as starting current (for example) for a motor and can be 120-140% of the actual continuous power.
Check you owner's manual, find the detailed specs which will normally contain the maximum continuous current rating. If it is listed separately for 120 and 220 (240) volts look for separate current ratings for each output.
By multiplying the current(s) times the output voltages you can find the total resistive output into a purely resistive load such as an electric heater.
For example: 120VAC X 20 A=2400 watts. If other outputs are available such as 220VAC, multiply its current rating: 10A. or 2200 watts Adding those two results 2400 2200=4600 watts will give you the rated power of a unit.
You can also recognize stupid power claims if the engine's horsepower is given. One (US) HP = ~746 watts. Since no generator is 100% efficient, its a fair rule of thumb to guesstimate the available electrical power at ~70% of the engine's rating (although, this is often also wildly optimistic). 10 HP X .7= ~746 X 7 or a bit over 5,000 watts.
Oct 03, 2010 | Craftsman Electrical Supplies
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM049700 need to know what kind of oil to use and replacement sparkplug
we need to know the make of the motor....most use a SAE30 four stroke oil....not sure of the plug without knowing the make of motor.
Jul 23, 2010 | Coleman Powermate 7,000 Watt 13 Hp...
Electrical Supplies Logo
35 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
