Question about Jandy AquaPure Ei Series 35K Salt Water Chlorine Generator
Jandy aquapure 35 i have had mine installed-hard wired, by a pool contractor 4 2 months, and all of a sudden it just died. No power to the control unit. Fuses blown ,new fuses blown as soon as power restored.?
  • David Spradling
    David Spradling Oct 16, 2017
    sounds like cell is shorted
    Habit-Forming:
    New Friend:
  • 111 Answers
Hi
it looks that there is short circuit from the power source to the control unit.
put a temporary supply to the control unit if this works there is a fault from the power source to the control unit.( short circuit power going to earth ) if it the same then there is short circuit from the control unit to the auxiliary
Posted on Jan 13, 2018
  • 22 Answers
SOURCE: jandy aqua link main control box
Do you have a 4 button switch in the spa and is the light on the button that is slightly under water? If so , the button is bad as the water is completing the circuit and turning the light on and off.
Repalce the button or disconnect it at the outdoor panel.
Posted on Dec 21, 2008
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
Posted on Feb 26, 2009
  • 16 Answers
SOURCE: Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
Posted on Jan 16, 2010
  • 21 Answers
SOURCE: FL 4 error, Jandy Lite 2 pool heater
I believe you may have a draft restriction and this may stop the start up diagnostics. The draft detection switch is sometimes restricted or weak. Common problem. Tap the gas valve to see if the winter has caused the valve to seat heavily and stick.
Posted on Apr 25, 2010
SOURCE: Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Posted on Jul 08, 2010
Aquapure installation
you have to have some kind of switch or relay hook the aquapure to the leads of pump so when pump is on it is
Sep 28, 2017 | Pool & Spa
Set aquapure not appearing on main menu
go into system setup you should see aquapure if set to 0 it will not show on screen also make sure the aquapure red 4 pin connector is plugged in so the PCB board and the PDA can see it
Oct 19, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
P D A pool digital assistant
go into set up menu and activate aquapure 5% and up then it will show up on screen if on 0 thats off and will not show up also make sure wires are connected to 4 pins
Jun 07, 2013 | Jandy AQUALINK RS TELELINK KIT
Jandy PDA not showing water temp
sounds like a loose wire on the red 4 pin connector to get water temp filter pump must be running lost of times closing crews disconnect that stuff if that doesnt work give me more info
Mar 02, 2013 | Jandy Aqualink Pda P8 Wireless Pool or Spa...
HELP!! My Jandy PDA lost menu items, and I can't get them back!!
increase the aquapure output to5% or more it will show back up on PDA
May 28, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
My jandy pda won't pickup aquapure salt generator
go into system set up youl see aquapure move it from 0 to at least 5% and it will show up that is if the red 4 pin is connected in the aqualink
Jul 28, 2010 | Jandy Aqualink Pda Ps8 Wireless Handheld...
I have message on pda "check AquaPure general fault"
SALT GENERATOR IS NOT WORKING OR SENSOR ARE BAD SEE AQUAPURE READING FOR CODE YOPU MAY HAVE TO CHAGE IT
Dec 06, 2009 | Jandy Aqualink - Rs32 One Touch Pool / Spa...
Jandy AquaPure Ei Series 35K Salt Water Chlorine Generator Logo
179 people viewed this question
Top Jandy Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Jandy Electrical Supply Expert? Answer questions, earn points and help others
