Question about Xerox WorkCentre M940 InkJet Printer
Error message; no printing of text
I got this pop=up message when trying to print material. "Some of the printer's settings may be overridden by your application's print options." No text prints. But I can hear it printing. I've changed printer heads, ink cartridges, etc. However, I may have triggered something when I tried to set up my scanner and fax components. But I don't know how to get back to what I did....thanks
  • bzoe Aug 30, 2007
    It happens all the time. I use software and Mozilla Firefox for my internet. When I copy information for example a job posting here at Harvard, the copy prints just the colored logo, and side bar blue categories, but not the guts that are in black. Nor from the OpenOffice, will it print my letters. So, I don't think it makes any difference what is on. However, I must say I tried to get my scanner and fax up and going. But being semi-illiterate in this business, perhaps I snaffued something and didn't know it? Still can't scan, nor fax. URgh. Many thanks BZoe
It display error message,saying i should refer to user guide
Posted on Apr 15, 2010
  • 390 Answers
What application were you trying to print from at the time. Does the printer give this error message all the time or only from this program? I need this info to assist you bzoe...lilacgerry
Posted on Aug 30, 2007
  • Geraldine Watts Aug 31, 2007
    Ok lets go for basics first, and you are most welcome. Let's reset the deafult settings in case you accidenatlly changes something. Turn the whole unit off, unpug it, all cables, replug it and turn it on. Go to your pc printer icon and scroll to properties. Check to see any settings are not ticked such as print offline or pause or similar. If they are, uncheck them. Now, go to printer icon again, find where your default settings are (usually in properties too) and click anything that says restore settings, default settings etc. This should fix all issues.
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
Error while printing message
Please try to powerdown your Printer and then your computer. Please restart both.
If you still are having the problem, then:
Try deleting and adding the printer again and see what happens from the printer setup utility if you are not able to print under another user and repair permission doesn't work.
Jan 09, 2008 | Brother HL-2040 Laser Printer
he front panel Your printer's front panel is located on the front of the printer, in the center. It has the following important
Assists you in troubleshooting issues
Is used to perform certain procedures, such as cutting and unloading paper
Displays helpful animations to guide you through procedures
Displays up-to-date information about the status of the printer such as, the ink cartridges, the
printheads, the paper, and the print jobs
Displays warning and error messages, when appropriate, along with audio alerts to call attention
to a warning or message
Can be used to change the values of printer settings and thus change the operation of the printer.
However, settings in the front panel are overridden by settings in the printer drivers, see
Oct 30, 2014 | Office Equipment & Supplies
Pcl xl error error: insufficient memory operator: rectanglepth position : 751 How do i correct this problem
The possible reasons for this error message are as follows:
  • The document is containing both image and text.
  • The font is not supported.
  • Embedded fonts are used.
  • A special plug-in is used.
This issue can be fixed by enabling the following option in Printer Preferences .
To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet CM2320 MFP Series PCL 6 , and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Rameshkumar . R
Aug 24, 2011 | HP LaserJet P2015 Printer
Error messages and printing problems
Paper mismatch errors occur because the printer scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper size error'.
Try to adjust the printer and envolopee settings..
Apr 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
I have an HP Color LaserJet 3800 printer. I am trying to print a document and it keeps printing: PCL XL error Subsystem: GEDI Error: MemA L LocError Operator: ReadImage Position: 743
That means that the printer does not have sufficient memory tp [rint the document, if it is a text document (eg word) try to print pages in groups, if it is a different document try the following:
" I receive a 'PCL XL error' on my HP 4100mfp when making a 2 page copy as one page in duplex? Why?
The problem is related to a printer memory problem.
If following parameters are set in the HP 4100mfp you will receive and 'Insufficient Memory" error.
1) In 'COPYING' the 'IMAGE QUALITY' is set to 'BEST'
2) In 'ORIGINALS' the 'CONTENT' is set to 'PHOTO'
Following error message is printed:
PCL XL error
Subsystem: GEDI
Error: InsufficientMemory
Operator: EndSession
Position: 32
The solution is to set 'CONTENT' to 'MIXED' or 'TEXT' or set 'IMAGE QUALITY' to 'NORMAL' or you can add additional memory to the HP 4100mfp. "
from - FAQ
Dec 22, 2008 | Office Equipment & Supplies
Epson cx4800 - will print in text mode but gives me a paper jam message in photo mode pape ris not jammed
It sounds like a driver issue. Have you tried to uninstall and reinstall the software on your computer?
Nov 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Printer malfunction
2 possible soultions,
1. The color required to print the text ( ie: black or a variation of ) may have run out and needs to be refilled or replaced.
2. The other way that could help, is to select only the text you wish to print, by highlighting the entire text of the email, and then press and hold Ctrl while you press P to bring up printing shortcut menu and then check the "Print selected only" before attempting to print.
This should give you only the selected text, but if your black or the color required to print is empty, it may appear blank on the page, or show a low ink error.
Jan 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
Will not switch on and both red lights keep flashing
disconnect printer, uninstall drivers, reinstall drivers & connect printer for set up new printer. let me know what happens.
Oct 28, 2007 | Epson Stylus C66 Inkjet Printer
Xerox WorkCentre M940 InkJet Printer Logo
102 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
