Question about Dehumidifiers
Manual KUL dehumidifier KU34313 - Dehumidifiers
My Kul Dehumidifier filter keeps freezing up? is there anything I can do to keep this from happening?
Turn the knob to a lower setting so that the unit cycles on & off. This will give it time to warm back up and melt the ice in between dehumidifying runs.
Aug 30, 2015 | KUL 50 Pint Dehumidifier"
I have a LAD704DUL frigidaire dehumidifier that will not shut off after being shut off, and not until the plug is pulled. Is this worth getting fixed
Dear Peter Nicolle,
according to the user manual the dehumidifier will not stop running for the following 5 reasons:
  • Windows or doors near dehumidifier are open to outdoors.
  • Area to be dehumidified is too large.
  • Air movement through dehumidifier is blocked.
  • Dehumidifier has been installed or restarted recently.
  • Dehumidifier is in the CONTINUOUS mode.
You can find more information on the user manual on page 9 under the category DEHUMIDIFIER RUNS TOO MUCH.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0220en.pdf
Nov 30, 2014 | Frigidaire 70-Pint 2-Speed Dehumidifier...
I have a model KU 34313 Kul dehumidifier and i cannot get it to stay running , I plug it in and it runs for 2 minutes and then shuts off? cannot find manual
We too have the same problem but it is with the KU34513 Model it may last a whole 15 minutes max then shots off with ERR message.
We bought it after last recall.Now there is another recall. Is this a safe model? Fix or replace?
Jun 28, 2014 | KUL 50 Pint Dehumidifier"
EC appears and it doesn't draw water
I contacted CE North America customer service regarding this issue for same unit. They suggested disconnecting for 10 minutes, then reconnecting, turning unit on, and changing settings and run fan on HIGH or TURBO until the EC code goes away. This didn't help with my unit. If this doesn't work, there is no repair provided. Customer Service recommended returning unit to purchase location if under warranty (1 year), however a copy of the original purchase receipt is required. Suggest a call to Customer Service Center at 866-915-1212.
Jun 01, 2014 | KUL 30 Pint Dehumidifier
How do you turn on the 30 pint KU34313 dehumidifier
I think you have to put water in it then push the start switch. The manual has a complete set of instructions.
Feb 21, 2014 | KUL 30 Pint Dehumidifier
Kul dehumidifier error code as unplug and plug back in still has the error code.
"For the above error codes, Power the unit off, and then unplug the unit for 15 minutes. Plug in and power on. If the issue persists, please contact customer service."
https://edgestar.zendesk.com/hc/en-us/articles/201000315-My-dehumidifier-is-displaying-an-error-code-What-does-it-mean-
Apr 28, 2013 | KUL 65 Pint Dehumidifier
I have a 30-pint KUL dehumidifier that works GREAT and is fairly quiet. My question is: the air that flows from the vent is lukewarm at best and sometimes warmer than that. If the a/c is on, this affe
A/C removes the heat found in the air and so gives out slightly warf flows but normally this is cooled of by water but that is why air con home units are vented to the outside atmos
Sep 21, 2012 | KUL 30 Pint Dehumidifier
Dehumidifiers Logo
209 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
