Question about Medical
Dental chair Hello, I have gnatus dental chair, and the problem is, that hydraulic oil going out from the chair, I am not using for moving up and down, because of it, today this happened, can you give me advice for solving this problems?? Thank you
  • 531 Answers
Gnatus technical assistance.
Posted on Sep 09, 2016
    New Friend:
Have to call the gnatus dental technician...
How do i fix a office chair that will not stay pumped up?
Your chair will not stay pumped up its due to the hydraulic pump thats in the chair all you have to do is find out the length of the hydraulic pump go online and Google hydraulic pump replacement and buy it from them
Dec 25, 2015 | Furniture
I bought a TP 4000 chair at Staples today and when you sit in it you immediately sink like the hydraulic cylinder that allows you to adjust hieght is bad. Any ideas??
It could be faulty, but there is a arm under the seat that should allow you to adjust it, exercise that lever, perhaps the valve is stuck.
Jan 02, 2015 | Seat Cars & Trucks
How to release a telescoping office chair
The information on this web page may be helpful. If the height adjustment lever is working fine then best to replace the gas lift cylinder. Help My Office Chair Keeps Sinking
Aug 19, 2014 | Furniture
I need bay a 3 to 5 trophy x ray tube trx708 dental
Try to consult with the dentist that may give better ides as well as you can know about the bay dental, which I know about DentistsinmobileAl here you will get more detail about bay dental.
May 17, 2014 | Trophy TRX708 Dental X-Ray
Chair is stuck in a raised position
Hello. The chairs lift needs to be cleaned from the inside and the hydralic fluid changed.
Apr 18, 2014 | Flight Dental A10E Patient Chair
HELP ! My Rascal joystick has option to raise & lower height of chair; I raised it to get in my freezer and now it will not lower. When it is in the RAISED position, the speed is less than a ONE a
This device either is hydraulically operated or operates use a motor and jacking screw, which is much more common. Take the seat off the jacking post. Put a piece of wood on the top where the seat was mounted. It should make the same kind of motor noise going down as it makes going up. If it never made noise going down it probably because its a hydraulic system so the down button activates a valve opening a hydraulic line allowing fluid to flow out of the chamber holding the piston up that your chair is mounted on. If it did make the same kind of noise going down, its a screw jack type mechanism. In either case hit the top of the wood once with moderate force. I like using a 5 pound hammer. I call it my master calibration tool. Make sure you strike the top of the wood piece straight down in order to avoid bending things. Try operating it now sometimes things get stuck when moved to their limit. So push the reverse button, then tap the piston down. You can check to see it the motor is getting voltage you will need a 24v circuit tester
I would like to see pictures of his devise. Any tag or stickers with who made it, model number?
Jul 28, 2012 | Electric Mobility Rascal Scooters,...
Medical Logo
488 people viewed this question
Top Medical Experts
Andrew Taylor
Andrew Taylor
Are you a Medical Expert? Answer questions, earn points and help others
