Question about Janome Mini Compact
Singer Model 324
I've recently come across this nice little sewing machine but I know nothing about it. I'm not even sure how to thread it. Would greatly appreciate any help provided.
  • Anonymous Dec 26, 2008
    kenmore sewing machine 15358
  • valerieedwar May 02, 2009
    dont no how to thread this machine
  • 625 Answers
Go to this site. it is the singer sewing machine company. they have the instruction manual for your 324 featherweight Plus - they charge $15 for the manual. http://www.singerco.com/accessories/manuals.html
Posted on Aug 30, 2007
How to thread tension on my L47 singer sewing machine
Threading and tension are two different things.
You can search for a manual:
Make Model manual
or
Make Model threading
(most machines thread similarly so even if you don't find your specific model, the instructions would be helpful)
https://www.manualslib.com/products/Singer-L47-4062252.html
When threading, be sure to ALWAYS RAISE the presser foot so the thread will seat completely in the tension disk.
For tension, generally start with the tension set at the midway point. Tension is correct when the top and bobbin threads meet in the middle of the fabric. If the bobbin thread is showing on the fabric top, loosen the top tension. If the top thread is showing on the underside of the fabric, tighten the top tension. Do not adjust the bobbin tension until it has been determined that the top tension does not make the adjustments needed. (Bobbin tension is sensitive--a little change makes a big affect so you will need to know how to reverse any changes you make.)
Understanding Thread Tension Threads
Jan 15, 2018 | Singer Sewing Machines
Where can I get an instruction book for a Singer 324 Featherweight plus sewing machine?
Right on the Singer site--it's a free download. On their home page, there is a category called "Support and Resources," and one of those categories is "User's Manual." Just enter your model number in the box.
Sep 17, 2014 | Singer Sewing Machines
New Singer 1507 user - cotton jamming everytime
try this link for a free manual just in case you don't have one
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
if the fabric is real light weight you may have to use a stablizer
also check to make sure the needle is the right one for the fabric being sewed..
make sure the bobbin is turned the correct direction, try putting the bobbin in the opposite direction..
if the machine keeps jamming, take it back up where you bought it and show them what it's doing and see if they can help you..
Jun 20, 2013 | Singer 1507
I am using my mother's Singer Futura 1000 machine - probably around 20 years old but has been little used until recently. The bobbin thread has started wrapping itself around the bobbin multiple
try changing the needle
check to make sure the top thread has not come off the thread take
up lever
it could also be a problem with the timing and the machine
would have to be checked by a technican
Nov 26, 2012 | Sewing Machines
Singer featherweight model 324 - the needle position is in the left position and I don't know how to centre it - or is it supposed to sew in the left position
i looked up the manual and didn't see anything about needle position. Here's a copy so you can read at your leisure.
http://www.singerco.com/uploads/download/b5b49ead132ff755bc0af82a53d04326e2f60251.pdf
Oct 11, 2012 | Singer Sewing Machines
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
Cannot get the bobbin thread to loop with the top thread on singer 338
correct timing is when the needle is fully down and is just starting to go back up
at that point the hook should be just about at the eye of the needle
past or before indicates that the timing is out
way out can be the belt that drives the bottom section and just a bit can be the adjustment for the needle crank on the sliding shaft at the front of the machine
Jun 26, 2017 | Sewing Machines
I have a singer simple 3116 sewing machine and it stitches loose upper threads. I?ve tried adjusting the tension, re threading, flipping the bobbin around, and even different fabric. But nothing seems to...
Insert a new needle, (flat side facing rear of machine), now totally rethread. Try this, with presser foot up, pull top thread, it should pull smoothly, now lower presser foot, the thread should barely move. This should seat the thread in the tension discs. If that doesn't work, call Singer at 1-800-4singer.
Dec 27, 2010 | Singer 3116 Simple
Janome Mini Compact Logo
2,751 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
